PDA
View Full Version : Technical help Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 [81] 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114
  1. moving an exhaust 1/4 inch
  2. HAVING TROUBLE WITH DOWNPIPE BOLTS
  3. Dash Swaps
  4. Please can people measure something for me?
  5. Low speed missfire/cutting out 4x4 saff
  6. puttin collets on valves
  7. S2 misfire and popping and banging when under load on boost
  8. EFI CVH ECU's
  9. 4wd engine with 2wd sump....question
  10. dash coming to life
  11. 8 Injector Escort Cossie
  12. would a
  13. will 4x4 cossy head fit 2wd block
  14. 2.0l zetec strange engine prob with pics
  15. Coil pack
  16. ford escort turbo diesel luke warm heater
  17. what is the stroke of 2.0 moneo block?
  18. Solenoid Control Valve ERST
  19. none runner
  20. What gaskets to change in a rebuild?
  21. saff coz spulttering at high revs????
  22. Oil pump question ....
  23. FUEL CELL
  24. green injectors
  25. frst lump into mk6 esc 1.4
  26. Please clue me up
  27. cozzy wont start
  28. MBE 956 Map - Ford Pinto on TB's ??
  29. Turbo help needed
  30. Brake Discs
  31. 1.8 zetec turbo into mk3 fiesta
  32. fuel problem on turbo conversion
  33. BD10 and BD14 Camshaft
  34. Cosworth TPS
  35. audio
  36. How do u set the fuel pressure
  37. 3 door steering rack . help .
  38. Urgent information required (fitted an MSD chip)
  39. Plenum chamber
  40. How do you fit ST170 front brakes to mk3.5 Rs1800 Fiesta?
  41. Converting a Sierra from LHD to RHD?
  42. interior problems
  43. lag
  44. escort mk3 diagrams>
  45. BRAKES
  46. intermittant misfire
  47. Need help battery drain with clifford alarm and boot light.
  48. Cosworth idle
  49. 18s on a saff
  50. mk 2 escort brakes
  51. help with my 2wd saff please
  52. help with s2 rs turbo please
  53. alloy wheels and tyres
  54. Piston tops
  55. wrong chip fitted and now got problems
  56. F*cked up my S2 again...help needed
  57. running lean
  58. 1.25 zetec fiesta running issues
  59. Cossie heads .... ???
  60. Lambde sensor
  61. VW Head Units
  62. mk3 xr3i rear brake lights not working all the time and bat?
  63. TPS question
  64. Heated Rear Screen not working
  65. ESCORT LX 1.6 problems
  66. what Gearboxs can i use?
  67. oiltemp. and consumption
  68. does any one have a ofab map sensor for sale
  69. fuel gauge and temp?
  70. Mondeo rims onto a mk4 escort
  71. Battery light staying on,mk3 fiesta 1.3
  72. heater matrix
  73. Turbo Charging EFI XR3i
  74. Cam Belt Change
  75. Removing Dump valve
  76. Can you still get these ?
  77. Clutch?
  78. cant get reverse
  79. escort better brakes??
  80. ANY1 KNOW OF GOOD ERST TUNNING SITE
  81. overboosting problem-2wd cosworth
  82. How does this come apart????
  83. Escort P8/L8
  84. Non Starting s2 Please help
  85. Boot Leaking????
  86. and another problem [over heating]
  87. Is it possible
  88. What is the phase sensor gap ment to be in a cossie dizzy???
  89. turbo housings
  90. 2 things need help with
  91. FRST Running Lumpy
  92. white smoke
  93. xr3i head differances
  94. RST who wont go correct on full throttle
  95. ELECRICAL HELP NEEDED
  96. Custom Engine mounts
  97. Major Problem With RS1800
  98. intermittent loss of speedo and revs
  99. knackered spring??
  100. checked the turbo
  101. shapp 4x4 coz into mk3 van ? any one help
  102. hand brake cable!!!!!!!!
  103. IMPERAIL BLUE ESCORT COS PAINT CODE
  104. AP BRAKES
  105. RST non starter
  106. frst anti roll bar
  107. stage 3 - standard diff
  108. handbrake light on S2
  109. EFI Parts question
  110. ANY1 REBUILT A T3 GARRET TURBO
  111. **non ford** audi cabriolet electronics anyone?
  112. is this turbo worth buying if i can get hold of it?
  113. saph 2wd missfiring badly! help!
  114. ke jet
  115. Help! Ford Focus....
  116. 2 litre zetec Turbo into a 1800 XR2i...Help please?
  117. ANY 1 KNOW WHERE I CAN GET A TURBO ON FINANCE
  118. Zetec conversions
  119. Battery question
  120. bad vibration on my escos
  121. non starter
  122. Series 2 starting problem when hot
  123. BENO'S ZETEC TURB PROJECT
  124. mk1 RE-WIRE
  125. what triac to switch injectors on L6 ecu (bdx53m)?
  126. saph abs
  127. Saff Oil Separater / Breather
  128. escort cos imperail blue (HELP) PAINT CODE)
  129. t25 elektron valve
  130. Paint Code....
  131. Clifford Alarm 'Chirp'
  132. breather tank
  133. gear box and idle problems
  134. frst coughing help
  135. PATS modul
  136. 2.0 16v zetec engine Escort MK4
  137. Vehicle dynamics ??
  138. Part numbers
  139. Escort topmount
  140. How do you adjust the mixture for an MOT.
  141. ADVISE PLEASE: engine mods for my car
  142. UNLUCKY OR WHAT
  143. COSSIE 4X4 AUTOMATIC CHOKE???????
  144. help zf plated diff for 4x4 cos
  145. HELP!!! HAV I FITTED MY DAD TURBO DAMPER RIGHT????
  146. XR3i Brake FLuid
  147. wheels help ... urgent
  148. the wire that goes to the nocharge light from the alternator
  149. rear diff
  150. omex engine managment
  151. 2wd cossie
  152. engine tuning help
  153. DIS converted escort cos rev counter prob ???
  154. rear diff bearing sizes on cos 4x4
  155. temp guage escort
  156. sierra 2.0 dohc gear prob
  157. zetec manifold material
  158. Clifford gone silent :(
  159. Pin Data
  160. zetec sump swap...........
  161. DTA Management Question
  162. Help - Noisy Fiesta at 4K revs!!!
  163. Secs monitor manual
  164. HELP! MY MONDY (Mk3)DASHLIGHTS DAZZLE ME!
  165. newbie looking for advice.....
  166. phase sensor??????
  167. Engine prob, what do you think it is?
  168. RS2k @ deaths door
  169. FIESTA ZETEC TURBO
  170. pectel t2 question
  171. oily smell and drink problem
  172. 2LTR ZETEC 16V OIL PUMP
  173. reconditioned turbo
  174. amal valve t25 escort cosworth
  175. Cosworth ISCV
  176. HISPEC 360/32mm with 6 POT Big Brake Conversion
  177. s1 uprated intercoolers
  178. escort cosworth t25 amal valve
  179. Ka Zetec 2.0
  180. ABS Wiring need help :(
  181. Samco hoses
  182. HOW HARD IS IT 2 FIT THIS.......
  183. zetec turbo question
  184. Testing ESCOS Amal Valve
  185. 2wd steering coupling
  186. Mondeo Blower/Fan Problem
  187. 3 bar MAP sensor versus 2.5 Bar
  188. Is this supposed to look like this???
  189. brake bleeding problems!! s2 with abs
  190. Anti lag questions
  191. escort rs2000
  192. 2.0 fiesta si
  193. Two esccos questions, 1. speedo swap, 2. coil pack
  194. colour code
  195. Possible problem with my ka Rs Turbo!!!
  196. S1 RS Turbo Problems !!! Help me.
  197. Borg & Beck Clutch
  198. Im puzzled
  199. Cd player??
  200. excessive play ni steering wheel on s2???
  201. Original ERST ignition advance map\table
  202. abs light stuck on
  203. Help with my Shopping List
  204. Injectors
  205. Puma / fezzer steering rack
  206. In desperate need of MTX75 Transfer box
  207. cossie brakes on ka
  208. Converting an XR2i loom to run a Fiesta Turbo?
  209. S1 Fuel Pump Relay
  210. Toad Alarm Probs
  211. Cosworth throttlebody
  212. sierra v8
  213. mk3 fiesta advice on engine change
  214. grinding noise
  215. grp a fuel pump
  216. radio code
  217. Help with MONDEO ST200 please!
  218. Bleeding cossie brakes on a ERST?Tried to search,please help
  219. bleeding escort brakes
  220. series 1, no fuel to injecters
  221. Rotting fuel cap area
  222. Rotting fuel cap area
  223. Zetec Coil External Amps? (Update)
  224. need help pliz
  225. Dash Problem on Focus...., No speedo, rev counter etc etc
  226. rs turbo oil
  227. S2 RST Weight problem
  228. escort s2 DIM Headlights
  229. ABS Light - Escort RS Turbo S2 ...
  230. Help clifford alarm gone mad
  231. breather again
  232. zetec in my sierra
  233. wheel help needed s1
  234. big valve CVH head
  235. please please someone help my saph is dead
  236. Escort Cosworth limp home mode.
  237. 2wd cosworth rear diff hanger
  238. Changing Escort PAds!
  239. Escort zetec, mk6. 16v (p) clutch help
  240. 2wd rear diff oil
  241. Slimline fan for S2 RST
  242. Cosworth Management? Which is best?
  243. mark 5 fiesta cutting out
  244. Focus RS engine into A ka.
  245. fuel pick up problem maybe...
  246. ERST s2 water temp
  247. help my taxi
  248. driveshaft coss 4x4
  249. OverBoosting ERST S2 Problem
  250. zetec breather kit
