bad vibration on my escos
Old Dec 11, 2006 | 03:11 PM
TONY F's Avatar
TONY F
Default bad vibration on my escos
just wondering if any one can help, i have got a bad vibration on the steering wheel, it only happens at about 55mph then it goes off at about 65 mph, i have had the wheels balanced at two different places so i don,t think it is that and don,t think its the disc,s either,
cheers tony
Old Dec 11, 2006 | 05:52 PM
Alvyn's Avatar
Alvyn
warpped discs,ball joint knackered,shockers,antiroll bar bushes worn the list could go on tbh! seems like it's going to have to be a case of elimiation
Old Dec 11, 2006 | 08:49 PM
TONY F's Avatar
TONY F
cheers m8, its defo not the discs the bushes are quite new
could a worn shocker cause this
Old Dec 11, 2006 | 09:11 PM
Alvyn's Avatar
Alvyn
yes, couple of other things to check/try putting the front wheels on the back and check it then and have you got the spigot rings on the inside of the wheels as these DO help centralise the wheels to the hubs?
Old Dec 15, 2006 | 05:58 PM
TONY F's Avatar
TONY F
changed the wheels round and its still the same
so any more ideas what could be causing it
cheers tony
Old Dec 21, 2006 | 04:44 PM
philbert's Avatar
philbert
Default bad vibe
Hi there had the same problem with my sapphire have U checked the bulk head bush on the stearing colum
Old Dec 23, 2006 | 12:20 PM
TONY F's Avatar
TONY F
cheers m8, seems fine though. will have to change the shocks next
Old Dec 23, 2006 | 12:26 PM
Alvyn's Avatar
Alvyn
try tightening the sub frame bolts also! infact just go round all the mountings, like bell housing/gearbox mounts bolts etc!
gcfcos
59
Oct 6, 2015 05:04 PM
Fordmad!
Sep 29, 2015 07:03 PM
talon1
Sep 15, 2015 10:27 AM
Mickeystewart
Sep 9, 2015 04:04 PM
