Please clue me up
Old Dec 25, 2006 | 12:46 PM
NJ-'s Avatar
NJ-
Default Please clue me up
I would like to be educated on engine coolant.
At them moment I have a fez 1.25 zetec, and only have water & anti-freeze for engine coolant.
I was told that it would be better to use the Ford red coloured engine coolant for better results and performance.
What do you guys use? are there any good products out there specially made for this purpose?.
any advise or help is great.
cheers.
Nigel
Old Dec 25, 2006 | 01:05 PM
Alvyn's Avatar
Alvyn
what you have WILL be fine! you be better of worrying about the amount of oil it uses!
Wardy257's Avatar
Wardy257
Ford will reccomend their own engine coolant. However, as long as you use good quality coolant and the proper mixture you will be fine.
I tend to use the cheaper stuff and have had no problems, even when I lived in the north of Scotland.
PS Coolant is antifreeze, anti-freeze is coolant (in the UK).
Old Dec 25, 2006 | 01:26 PM
NJ-'s Avatar
NJ-
Cheers for the advice guys, helped a lot.
Alvyn, my fez has been very good so far, have had it 7months and it has not drunk a drop of oil, I done a oil change when I first got it and since then I have not had to top it up.
thanks again.
Old Dec 25, 2006 | 03:18 PM
crash_ash's Avatar
crash_ash
thought you shouldn't mix the orangy / red with the blue tho, it's either one or the other, think ford changed to red in late 98 / 99. halfords red antifreeze melted the plastic sight glass in my pro alloy header tank.
Rizlablue
Sep 6, 2015 09:58 AM
Shell
74
Dec 10, 2009 02:49 PM
Disabled Account
14
Jul 28, 2004 09:13 PM
