Help with MONDEO ST200 please!
Hi all, am after some help.
Have got a 2000 reg Mondeo st200 that has been great since i bought it. The last couple of days i havce noticed the idle has been a bit high, and yesterday it was all over the place, jumping to 3000rpm when its just sitting there with the clutch dipped. It is also doing it in between gear changes....when accelerating it pulls fine but as soon as the clutch dips the revs rise...
Any ideas would be greatfully appreciated...
Ross
Ross
as above , there are 2 or 3 pipes coming off the main induction pipe just after the MAF check these for any leaks or pull them off 1 at at time and put you finger over the hole , if the revs drop then you have a pipe off or split
lots of pipe work to check do the works oil cap dip stick breather lines to bellows evap line under throttle body small vac lines at back of manafold check Iat sensor is firmly home in the bellows ICV pipe an gasket thats the unit at the back of the manafold next to the big pipe coming from the bellows .
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
The Enigma
Sep 29, 2015 10:31 AM
