PDA
View Full Version : Technical help Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 [94] 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114
  1. cossey garaged up for winter-battery charger????
  2. Cossie Is CRAP!! No Boost - any advice???
  3. White underseal/waxoil
  4. S2 RS Turbo tuning
  5. Escort RS Turbo ECU Chips, 3 Wire Jobby?Bit Sceptical
  6. hydraulic handbrake
  7. frst cutting out when u press clutch down to change gear
  8. zetec fly wheel spacing is it 36-1???????????????
  9. help, wheel problems
  10. bosch 803's what cc do they at what bar?
  11. Cosworth 2wd tuning advice
  12. Newbie Ford Ka Questions
  13. Mk3 xr2i
  14. escort gti interior
  15. cvh turbo lost power and running lumpy
  16. please help- installing a hydraulic handbrake
  17. Parts i will need for cossy management !!!
  18. How to remove a turbo housing?
  19. rs1600i susp. settings
  20. Ford KA Running On 3 Cylinders
  21. rs turbo gearbox for mk5
  22. smoking on idle
  23. Please help,im a beginner!
  24. gear box differents mt 75
  25. Sticky Valves
  26. 2wd engine loom diagram
  27. quick dump valve question
  28. what would cause
  29. clutch
  30. T5 gearbox...
  31. Brake hoses
  32. cosworth Fuses
  33. any 1 using megasquirt or used
  34. ford motorsport
  35. wiring for ford racing voltmeter gauge
  36. help
  37. Escort GTi IDLE PROBLEM
  38. s1 cutting out at 4k when driving
  39. cossie head - back on - problems?!
  40. zetec on R1 carbs
  41. Escort Van wheel wobble
  42. 3dr rear side window removal
  43. cossie 4x4 rear springs (lowering)
  44. 2.1 xr3i
  45. mk 6 clutch
  46. Cossie 4x4 stereo loom
  47. sapphire 4x4 TCAs
  48. I want to replace my YBP for a YB Cosworth engine.....
  49. 2wd cossie rear beam.
  50. best oil to use in escort zvh ?
  51. TT F18 4i turbo conversion/help needed
  52. Unichip fuel
  53. Sport KA Blowing out cold air???
  54. wide band a/f gauge
  55. smoke under bonnet
  56. Cossie rocker covers - different colours - why?
  57. cl on a mk5 escort
  58. mk5 headlights
  59. smoke and subaru sounding engine!
  60. Rev Counter on P8 with Dizzyless Question
  61. anybody good with audi,s ????
  62. escort gti interior
  63. any 1 know ofab wiring for zetec turbo in mk5 zetec escort??
  64. T3 Turbo Conversion - What injectors?
  65. Pulling to side under acceleration
  66. Speed pulse?????
  67. 4x4 cossie help
  68. Group a coil fitting
  69. clutch cable on fiesta rs 1800
  70. need to turn up fuel mixture on ERST
  71. hazard switch
  72. expensiv ?
  73. what diesel pump on 1996 escort van?
  74. cosworth engine wont start HELP!!!!!!!
  75. Escort GTI strange noise when starting
  76. 1.6 16v Escort Si (1996 N)
  77. Odd braking sensation on 2WD Cossie - PROB SOLVED :)
  78. xr2i running prob
  79. Technical Discussion: Cam Timing...
  80. sterring
  81. 1.6 RST Exhaust Bore and downpipe size 300hp??
  82. Water Leak
  83. best brake conversion?
  84. what size tyres
  85. kevlar or fibreglass body shell !
  86. MOT failure quick questions (steering and headlamps)
  87. standard piston crowns
  88. Won't start
  89. (Boring question) HOW OFTEN TO CHANGE OIL ON FIESTA 1.8D
  90. keeps jumping out of 3rd gear and stalling
  91. fitting c/l and e/w
  92. ignation noise
  93. whit dials
  94. escort gti door cards into a mk5b
  95. need some tuning advice for 2.8i capri
  96. RS1800 FEZZY
  97. Dodgy rev counter
  98. help needed with engine management
  99. fuse box m5 escort
  100. Speedo on 2.9 Granada
  101. zetec header tank????????????????????
  102. engine swap
  103. help
  104. escort interior light delay relay
  105. 3 door cosworth body kit.
  106. t2
  107. mk5 escort 'anti theft module'
  108. 1700 puma head
  109. ANY 1 EVER RUN FIFTH INJECTOR
  110. Focus RS - Turning BOOST down?
  111. low idle on 1.8zetec
  112. sierra pinto
  113. wheels
  114. how do u test yellow+brown switches on erst
  115. Saf cossie cut out and wont re start
  116. drive shaft on zetec
  117. Best welder for seam welding shell *amateur*
  118. smokey fiesta. help!!
  119. Escort rs spares
  120. binding brakes
  121. Sapphire Cosworth Mis-Fire
  122. Escort Cabriolet Electric window winders,slight memory loss!
  123. fuel
  124. injector question
  125. Stage1 Cosworth
  126. 4x4 cossie idle
  127. cvh or zvh
  128. Boost problems??? Popping??? EEEK!!!!!
  129. boosting sounding good big thanks everyone for there help
  130. series 1 ecu, how do i tell if its chipped?
  131. Escort rs cold start idle
  132. pictures of cut out lower rs500
  133. 2.0litre with extras (will if fit a fiesta mk4)
  134. revs???
  135. rs turbo cooling problems
  136. Ford Orion Problems
  137. Fitting a rear strut brace to a 3dr cossie,advise please.
  138. blue smoke on cold day =
  139. help with stereo
  140. amul valve i think
  141. Master cylinder sizes on a cosworth 2wd.SOMEONE MUST KNOW
  142. Possible electrical fault
  143. rs turbo series 2???are blue,red,black ecu's not too good? ?
  144. help needed
  145. chipping question?
  146. WHAT OIL PRESSURE ON ZETEC
  147. zetec turbo smoking when not boosting
  148. problem starting
  149. OFAC MAP sensor values
  150. removing abs from s2 rs
  151. wire for temp gauge on zetec
  152. white smoke on cold start up for 10mins fiesta turbo
  153. MK6 1.8 Zetec, Runnign problems
  154. BD10 inlet cam
  155. egr removal
  156. ERST Electrical Problem
  157. zetec turbo dump valve question?????????????????????????
  158. zetec turbo too much fuel
  159. XR2 Bodykit
  160. Whats the difference......
  161. Cosworth 2.0 16V Turbo motor into a MK1 Escort
  162. cossie rear axle into mk1 escort
  163. Guide to fitting twin 40s?
  164. What boost should i run?
  165. HELP no longer needed. its running fine now
  166. Braided hose for power steering
  167. FRST SICK AGAIN!!!! Anybody help?
  168. Long stud for cossie/pinto block
  169. how heavy is a rwd saff coss
  170. cossie keeps dying on me
  171. would it be possible to..............
  172. ecose missing under boost???
  173. is lower rs500 rear spoiler ...
  174. Cosworth 4 pot's onto escort rs
  175. Fitting polybushes to my saff
  176. Escort zvh conversion
  177. fiesta turbo brake bleeding???
  178. Turbo damper for cossie 2wd T34
  179. dificult to start rst,then runs very badly
  180. MY CARS SICK CAN ANYBODY HELP??
  181. taking cvh engine out
  182. Home made cabriolet door???
  183. Fuel regulater help?
  184. T34 Turbo
  185. cosworth bmw- mayo in breather pipes
  186. Probrably a dumb question about the CVH Camshaft oil seal...
  187. Painting brake drums
  188. 4x4 suspension! Will it fit?
  189. Fuel gauge playin up???
  190. Cossie - missfire at extreme high speeds
  191. ECU Speed output on cossie - for Blitz Power Meter
  192. can anyone help??/
  193. 2ltr 16v spec
  194. Mt 75
  195. Pectel Board Problem's! Please Help
  196. Cossie YB cams
  197. Width of a mk1/mk2 escort front?
  198. ford sierra 2.0 DOHC EFi not starting
  199. What coolant is best YB cossie
  200. losing oil pressure when engine warms up ?
  201. Cossie 4x4 front wheel bearings (near side)
  202. XR2i Breaking Problem
  203. fiesta 1.1 hcs engine over fueling was running
  204. XR2i TURBO CONVERSION
  205. A/F GAUGE U GOT
  206. GEAR BOX OIL??????????
  207. Clutch spec for 350bhp 2wd cossie, 4/6 paddle std cover HELP
  208. rs turbo smocking badly
  209. 3dr exhaust
  210. turbos
  211. lambda signal wire
  212. erst fuel pump
  213. Fiesta brake light wont go out!!
  214. lambda sensor
  215. Mondeo Turbo Conversion
  216. ring gap question
  217. wiring in gauges
  218. are any of these any use?
  219. ET40 offset would that fit a 3dr cos.
  220. MS90 Gearbox
  221. Replacing zetec pistons
  222. Engine maps....VE changes and Fuel pressure???
  223. is ther a tail signs if a valve was sticking
  224. ABS fault since fitting 330mm discs & calipers.
  225. whats the best alarm for erst S1?
  226. fiesta rs turbo on boost problem
  227. '89 escort popular van radio wiring/fitting help wanted!
  228. zvh conversion
  229. Whats the wheel offset on a escort cosworth
  230. Dropped valve collets
  231. Big end shells help?
  232. series 1 rst idle probs
  233. zvh engine
  234. squeeling noise
  235. ignition ???????
  236. piston and rings question
  237. Max. power/torque capacities for 7"/7.5" diff.
  238. Wilwood brake kits, are they good or not?
  239. BRAKE UPGRADE (HELP NEEDED)
  240. anybody datalogged from a pectel monitor?
  241. bodyshop
  242. Zetec- s overheating
  243. saff cutting out!!
  244. URGENT HELP PLEASE!!!
  245. throttle bodies
  246. 3bar MAP sensor
  247. Paint code
  248. 2WD Sapphire Cosworth Engine Wiring Loom
  249. Random Ford intercooler
  250. Quick Mappable ECU question
