1.6 RST Exhaust Bore and downpipe size 300hp??
Hi its my first post here.. I'm building up an RST 1.6 engine to race spec but unsure what size and downpipe i need to use... the aim is 300hp
I have steel rods , big valve head .. lighened bottom end etc and plan to run the GT28RS turbocharger.
I know i need to run a 3 inch downpipe.. i just wondered what bore system u guys are running .. as I was thinking a 3 inch system might be too big ?
Any ideas.. no silly answers.. pls
regards
regards
focus rs 1672
Originally Posted by xr3iturbo
usually 2.5-3inch is ok dont want alot of back pressure so 1 nice cossie box at rear should do good
i always thought smaller the better because of back pressure but couple years ago was told by a well known car modding garage (dont want to mention in case i get in trouble) that on turbo cars the bigger the better. Dont know how much truth in that but i personally noticed the difference in a positive way
focus rs 1672
an escort turbo is quite capable of makin 250bhp with a 2.5 inch bore exhaust
then after that it becomes restrictive so a 3" is then needed
pm christian and beccy,he went from a 3" to a 2.5" bore coz the 3" was too big for jis spec but had too go back upto a 3" bore when he took his engine further as it was holdin the power back
JK12
33
26-04-2021 12:09 PM
