PDA
View Full Version : Technical help Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 [87] 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114
  1. 90 spec ecu
  2. RS1800 no spark??
  3. s2 chipped ecu
  4. Wiring for gauges - mk4 escort/mk2 orion
  5. ABS warning light on, 2wd Cossie.
  6. Haynes manual for fiesta?
  7. rev counter on mk6 escort
  8. Electric rear windows
  9. Bleeding Cos 4x4 cooling system
  10. help help gti wiring on engine swap
  11. OBD 2006 focus
  12. can u paint suspention springs?
  13. 3 Door cos fuel problems
  14. Anyone good with cabby electric roofs???
  15. splitter Fiber glass \ carbon rs500
  16. Koni adjustables?
  17. 2wd oil pressure relief spring
  18. GTR32 non starter after rebuild, please help!
  19. spare tyre and mot
  20. Saxo/mondeo estate spoilers?
  21. radiator
  22. Will 4WD head fit 2WD???
  23. help with my setup
  24. Confirm my suspect head gasket.....plz(leak results)added
  25. what lowering springs for a 2wd cossie
  26. Best turbo for approx 310bhp (T3/T34)?
  27. Actuator Dead?? help!
  28. esc cos building from bare shell
  29. 2wd cossy head
  30. speed up!!! lol, speedo
  31. Oil Pressure S1
  32. escort cossie small turbo dv advice
  33. Ford fiesta cam timing
  34. Reprogamming keys
  35. how does anti-lag work
  36. Cant operate ALS
  37. Plug gaps
  38. ESCOS wheels on a MK6
  39. ET OF ESCOS WHEEL
  40. Non starting 2wd Saph
  41. ECU
  42. Temp gauge question ?
  43. Problems with my heaters
  44. 1.8 gti engine change
  45. escort s2 rs dump valve prob
  46. Small turbo manifold from escort onto 4x4 saph?
  47. oil light on at idle
  48. i wanna make my 1800 zetec into a zvh
  49. valve stem oil seals question
  50. 2wd cossie leaking oil
  51. S2 RST Immobiliser problem
  52. Pls Help!! - My M reg Fiesta Equipe cuts out...............
  53. Rev counter
  54. Saxo spoiler
  55. Mixture setting - K-Jetronic, CO value
  56. mk4 escort indicators not working
  57. solid followers
  58. rods
  59. mk 4 escort please help
  60. relay battery drain problem
  61. P8 ECU technical question
  62. Back Brakes
  63. Turbo for focus zetec
  64. No Fuel pump or crank after 130PS ECU Swap
  65. Escort Coswoth gear box rebuild
  66. Turbo manifold for GSXR1000..
  67. New VIN plates
  68. Zetec bringing LOTS of oil into one cylinder
  69. s2 ignition timing
  70. turbo size
  71. 3 Door rims on a mk3 Escort
  72. COSSIE WOUNT RUN WHY ????
  73. Info on rebuild
  74. breathers
  75. 200+rs not running right
  76. cvh rebuilding..
  77. turbo
  78. rs turbo starting/tickover problems
  79. Better brakes on a budget?
  80. s2 poor start probs
  81. tyre ware
  82. TIMING
  83. THOUGHT I HAD SORTED IT BUT NO NO NO NO
  84. too hot
  85. Help my mk1 xr2 temp says its to hot??????
  86. ABS 2wd cossy
  87. Advice Please
  88. my car cutting out
  89. Spongey Brake Pedal!!
  90. Temp stopping leaks
  91. escort cosworth turbo prob help needed
  92. Fuel System Modification! Tuners Help Us! Give us your Info!
  93. 16" SPEEDLINE ALLOYS ON TO S1 ?? HOW ??
  94. Changing the TPS on a 3dr cossie
  95. will a cosworth run
  96. How do i disconnect my ABS and is it reccomended?
  97. Tyres
  98. help?saff 4x4 abs....
  99. What spring and damper rates on Cossie coilovers do you use?
  100. Escort 1800 upgrade
  101. Escort Cosworth whats next after stage 3?
  102. TORQUE SETTINGS REQUIRED
  103. megasquirt problems??!!??
  104. Escort cossy fuel pump
  105. crank sensor fault..
  106. ECU prob
  107. Does the rs turbo s2 have a two diffrent types of engine?
  108. mini restoration 2wd saff
  109. Induction Kit/Suspension for Foucs, Advice Appreciated
  110. Wing mirrors advice
  111. escort fuel pump relay!!!
  112. Are my springs going???
  113. Windscreen washer bottle level sensor
  114. COSWORTH MELTED PISTON PLEASE HELP
  115. standard fuel pump
  116. Rear Anti-Roll bar mounts
  117. Non firing injectors??
  118. gearbox fault?
  119. Escort Cosworth Water Injection
  120. help.. erst wont pull, revs up ok on tickover but wont pull
  121. AAARGHH!! Holy Smoke!!
  122. Swirl Pot & Overheating
  123. ofab efi
  124. Temp problem
  125. garret turbo parts
  126. Cheapest and easiest anti lag system
  127. xr2i Thermostat Help
  128. zvht or zt?
  129. very weird problem need help !!!
  130. xr3i efi relay questions
  131. xr3i wiring diagram.. needed asap..
  132. L8 To P8
  133. A B S
  134. engine flush/cleaner
  135. alarm!!
  136. Power Engineering in Uxbridge/Slough
  137. H26 AFG SAFF COSWORTH
  138. replacing gaskets
  139. boost gauge?????????
  140. How to fit a dump valve to an escort rs turbo
  141. Is a std. RST T3 turbine wheel/shaft the same as 4x4 cossie?
  142. Rs turbo problems
  143. fuel pump prob on P8
  144. 4x4 sapphire cosworth - fuel filter washer sizes
  145. cosworth brakes on mk6 escort
  146. Misfiring Below 2000rpm
  147. Throttlebody for 1.8 130ps Conversion
  148. Mapping/set up question.
  149. CAR WILL NOT START!!!!!
  150. for all mot testsers and good machanics
  151. ARP stud and nut kit
  152. Clutch Cable...saff cos 4x4
  153. Welding question?
  154. dump valve on wrong?
  155. Cos 4x4 Overfueling proplem
  156. RST Turbo Oil Feed fitting?
  157. brakes on the van
  158. Inlet Air Temps
  159. I need a bumper
  160. Cossie Cam Belt Changing
  161. 1.8 zetec
  162. semi to full synthetic
  163. turbo conversion
  164. Electrical problems again !!!!
  165. ford ka brakes.....
  166. how to get turbo chatter,flutter etc
  167. Turbosport cvh steel conrods
  168. mk 1 mondoe alarm/imobiliser
  169. s1 turbo offset
  170. please help startin problem
  171. diseasil van q
  172. how to get 200bhp from s2 rs turbo ?? help
  173. Maram shaft?
  174. What Spark Plugs??
  175. zetec torque values ?
  176. Heated front windscreen
  177. turbo tank for van
  178. battery/alternator problem URGENT HELP NEEDED
  179. spark edis
  180. Help? Xenon Headlights!!
  181. cossie problem
  182. summer & oils
  183. escort gti skirts mk6
  184. ford edis
  185. Cossie Long stud Q
  186. Cosworth engine mapping
  187. rolling shell
  188. Mk 4 Fiesta burning oil
  189. Equal length DRIVESHAFTS!!!!!!!!!!!!!!
  190. Spoilers on mk5 and mk6 escort estates
  191. HELP HELP HELP ! MAP SENSOR QUERY
  192. will 7.5JX16 with 205/45 r16 tyres fit on an xr2i
  193. URGENT HELP BOILING WATER
  194. Noise on 4x4 Saff
  195. xr2i wheels, what size? cheers
  196. Ford Fiesta ZETEC 1.8 XR2I running problems
  197. rst s2 no fuel
  198. wheel bearing issue, s2 rst
  199. billet alluminium clutch adjuster
  200. s2 traking setting
  201. fiesta rst problem maybe electrical dont know
  202. FIA Cut-Off switch help needed!
  203. brake problem
  204. XR2i 16v / RS1800 starter motor......
  205. can anyone help, i need to know the name of this part ??
  206. Throttle bodies a Brakes
  207. which spark plugs and what gap?
  208. ZVH help
  209. weak engine bay
  210. efi HELP!!!!!!!!!!!!
  211. Duplicate keys
  212. How do i convert s2 block for a frst
  213. Big unknown prob
  214. best engine for 1.8 cab
  215. Mondeo Duratec ECU Mapping.....
  216. RS 7 Spokes
  217. quick shifts
  218. Setting valve clearances
  219. what parts can i use
  220. rst running 1800 cvh pully and alternator. what drive belt?
  221. -31 Actuator
  222. 2wd 1989 Cosworth engine Probs
  223. Saph 4x4 rev counter bounce
  224. erst cutting out!!!
  225. silver top 2.0 zetec t3 turbo piston probs
  226. drop a 2.1 zvh engine into my fiesta zetec s
  227. help
  228. fuel sender
  229. help
  230. xr4i parts
  231. cleaning bits and bobs
  232. turbo boost t3 conv!!!
  233. 2wd cossie turbo
  234. Tuners / Rolling Road in Southwest ....
  235. engine stand
  236. just fitted the veriners to my ZT now what ?
  237. Engine Management Computer
  238. 2.0 DOHC standard power?
  239. focus clutch
  240. setup@well lane turbo centre
  241. clutch
  242. valve stem oil seals on zetec
  243. 4x4 cossie rad fan on too much ...
  244. Icv???
  245. Mondeo Engine Problem???
  246. Cosworth engine + remote servo
  247. xr3i battery /charge how to check
  248. secs monitor
  249. cosworth hp oil pump
  250. FRST question
