PDA
View Full Version : Technical help Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 [111] 112 113 114
  1. DERV FOCUS TUNING
  2. 1.6 carb into mk5 escort 1.3 help
  3. Please Help - FRST Running Weird!
  4. Head Gasket Problems
  5. ford fiesta .......
  6. battery light s2 erst
  7. s2 erst thrust bearing
  8. Valve Guides for cossie
  9. NOS and turbo lag
  10. zvh oil pressure
  11. Adjusting boost pressure to what gauge?
  12. MK5 RS2000 plugg gap
  13. erst missing at 5000
  14. help!
  15. engine loom wiring problems
  16. piston - valve clearance
  17. NGK 9 gaps
  18. What is the offset for my Fiesta XR2i
  19. 130bhp ecu
  20. Upgraded mastercylinder for rear disc conversion HELP!!!
  21. what wheels on an s2?
  22. esc cos clocks???
  23. help nedded
  24. oil in inlet... turbo or other?
  25. Bet this gets you thinking!
  26. Crank Grinding & Balancing
  27. Oil breather Bailey mirror image
  28. More RST trouble
  29. Cosworth P8 ECU into a Duratec 2.3
  30. Dash for 3 door cosworth
  31. Another Hydraulic lifter Question, cosworth.
  32. cosworth tuning??????????
  33. URGENT HELP,PLEASE
  34. pectel monitor
  35. 1.9 CVH Help needed !!!!
  36. oil breather
  37. Cossie BHP
  38. whoosh, bang, diddly
  39. goodridge kits for sapph's
  40. escort rs 2000
  41. Twin pumps
  42. interia light/clock
  43. erst timing query
  44. saph wont start
  45. What boost shall I run?
  46. problem with 3 dr cossie
  47. s2 guage pod to replace trip computer
  48. Cosworth Oil Pumps and Spray Bars
  49. Fuel Computer
  50. fiesta gear box
  51. Set Pressure
  52. darn 3 dr won't start! relay fault?
  53. 4x4 Cosworth belt number/sizes?
  54. tyre wear?
  55. Wet Drivers Side Footwell, Any Ideas?
  56. xr3i problem
  57. Rear Camber
  58. RS500 restoration
  59. 1.6 CVH head onto 1.8
  60. What Gasket for a 1.8 ZVH ??????
  61. Information on thermostat and operating temperature
  62. Help with unreliable starter
  63. Head gasket
  64. Spark plugs
  65. clutch prob and hello
  66. Helix clutch
  67. Rubbing Saff
  68. stalling on idle
  69. rear tracking knackered?
  70. focus pre cat oxygen sensor
  71. 1800 zetec heads
  72. cossie tapping/knocking please help
  73. FAO all the GGR/philloy strut brace boys!!! Dave etc.
  74. Drilled/Grooved brake discs
  75. Help with identitfying intercoolers!
  76. Funny poppy noise idle valve
  77. Left Hand or Right Hand, Which Side????
  78. RECARO INTERIOR TO FIT IN KA
  79. need a new manifold for rs1600i,what fits?
  80. is my turbo knackered
  81. erst quickshift prob
  82. Cossie owners, how do u get around M.O.T emissions?
  83. 4b4
  84. Strut tops
  85. 2WD Head Port
  86. Confused Turbo
  87. The Same...Or Not The Same..?? (RST related)
  88. Cams
  89. Aftermarket ECUs for Cossie
  90. LSD for 2WD Cossie
  91. 4b4
  92. More Stage 3 Questions
  93. quick answer needed please
  94. s2 not always as fast as usual
  95. rs1600i- fuel pump problems
  96. Air temp sensor on cozy management HELP NEEDED SEE PICS
  97. clutch problem on sapphire cosworth
  98. Gearbox ID?
  99. Advice needed on 17" wheels for erst s2.
  100. ***NOT RUNNING RIGHT***
  101. plug leads
  102. Vibration under braking on 3DR Cos.
  103. new wheels
  104. cossie hi revs at idle
  105. coil packs
  106. CC's on 4x4 head
  107. 2.1 track car is gettin there , DOH was gettin there
  108. Cossie ABS removal
  109. Another misfiring cossie....
  110. serious misfire
  111. stripped stud
  112. cossie injectors/rst 5th injectors
  113. tyre pressue
  114. RST Temp Problems
  115. Randomly cutting out.......
  116. temp gauge
  117. amal valve
  118. microcat query
  119. does this seem rite
  120. Strong petrol smell on S2!!
  121. F*@~&$^ Cossie won't start!
  122. heated front screen
  123. crunchy gears
  124. Decent Dff and Gear box oil
  125. 4x4 cos vibration at 110mph
  126. What PSI?
  127. 2WD COSSIE NOISY ACTUATOR
  128. Question for Engine Builders?
  129. FRST Boost problems
  130. Wheres my oil gone???
  131. FRST Radiator Fan Always on! HELP!!!!
  132. .....SPEEDOMETER & MILEOMETER......
  133. I've messed up, need your help please
  134. Dead rev counter
  135. Saph cos hyd lifters
  136. 2WD COSSIE EXHAUST PROBLEM
  137. Rear drive shaft for mk5a RS2000 4x4?
  138. managment
  139. compression
  140. AP330mm front brakes under 17 inch ET40 Hockenheim R's????
  141. ford/cosworth engines..
  142. S1 with cossy brakes, problem please help!!!
  143. 3dr Engine Management Light
  144. RS500 oil
  145. brake pedal problem
  146. fuel gage problem on s1 pls help
  147. What Is Needed For Stage 3?
  148. smoking s1 pls help
  149. remote central locking
  150. No Oil pressure NEED HELP :(
  151. High Compression?
  152. Green or White? Left or Right???
  153. HELP PLEASE!!!!!!!!
  154. Cossie Rad Fans.
  155. 18in wheels on a saphire
  156. speedo cable
  157. T34 Turbo on S2
  158. Smoking cossie Ahhhhh !
  159. S2 ERST Alloys
  160. v6 cossie granada
  161. cossie brakes
  162. What wheel size???
  163. what cams?
  164. Caliper reconditioners
  165. ST170 brakes on S2 Turbo
  166. Where should I find
  167. MK5 Escort RS2000 couple of issues
  168. wont run all the time
  169. FRST Timming
  170. turbos
  171. spark plugs
  172. cams
  173. What does this mean?
  174. rs dnt wanna pull
  175. Power steering fluid
  176. burning smell
  177. CAM TIMING
  178. decisions decisions
  179. Offset
  180. dodgy running
  181. spark plugs??
  182. Fiesta Turbo Amal Help!
  183. Cosworth Rear Suspension
  184. stage three cossie wont rev
  185. what do these results mean
  186. Cossie starter motor, how much???
  187. Annoying dash problem
  188. Fiesta superchip question
  189. 2wd cossie front brakes
  190. is this an ecu problem??
  191. Car alarm wireing (escort rs)
  192. s2 oil?????
  193. 2wd cossie stage one boost
  194. Clicking noise when turning sharply . . .
  195. cossie steering on g3
  196. ECU advise needed
  197. t34 t35 t4
  198. running in oil
  199. 2wd Cossie Missfire
  200. cossie suspension on a 1.8LX
  201. 2wd Cossie Spark Plugs
  202. Cossie cuts out......
  203. Extend range on remote key
  204. Will any mk4 Escort Gearbox fit a Series2 RS TURBO?
  205. How much Brake Fluid
  206. Can you check map sensors?
  207. Fat red cable to starter from battery getting hot?
  208. where to get 3" stainless pipe?
  209. When Does Your Car Need A Remap???
  210. compression test ?
  211. Cracked Exhaust Manifold - Options?
  212. steering wanders
  213. No fuel to inj on ERST
  214. strange noises
  215. Altitude - Air/fuel ratio and boost
  216. MK1 Fiesta halfshaft
  217. 4 x 4 Transmission
  218. mk4 convertible hood
  219. Turbo repair or replacement. Its time to bite the bullet !
  220. Cossie problem
  221. best oil?
  222. best oil?
  223. saph petrol guage
  224. Intermittant misfire....
  225. Can I take down the sump without the x-member and engine ?
  226. 2WD Cos Differential oil & Level????
  227. braided brake hoses ?
  228. Traction Control
  229. What's diffenent about RS500 heads?
  230. zvh in a series 1
  231. xr3i (efi) fuelling problem
  232. Help Please!!!
  233. Ford Fiesta Freestyle 125 (2002)
  234. I'm back again...
  235. cossie misfire
  236. Changing seals & bearings on 2wd LSD????
  237. turbo knackered???
  238. Help, tapping noise from engine.
  239. Speedometer conversion
  240. 2wd exhaust maniflod blow
  241. Up and down temp gauge
  242. non starting cossie
  243. cossie 2wd water pipe running
  244. speedo drive sensor
  245. A.R.P. STUD AND NUT KIT TORQUE SETTINGS
  246. DUMPVALVES?
  247. Cutting out on boost
  248. Base idle..
  249. cosworth crankshafts
  250. turbo question
