FRST Timming
Old Mar 20, 2004 | 02:39 PM
Windle's Avatar
Windle
Default FRST Timming
Do you set the fiesta turbo to both bottom pulley and top pully at TDC or bottom about 8-12 degree's??
Old Mar 20, 2004 | 04:16 PM
PJay's Avatar
PJay
Get somebody that knows what they are doing to do it for you
Old Mar 20, 2004 | 05:58 PM
Windle's Avatar
Windle
real helpfull that mate cheers
i know what i am doing just dont know the timmimg as i used to be MFI now am EFI
Old Mar 21, 2004 | 08:09 PM
Both at TDC mate!
With greatest respect though it doesnt sound like you know what your doing as MFI is both at TDC too, the timing is adjusted by the distributor. On the EFI the ecu controls the timing!
Dave.
Old Mar 21, 2004 | 10:42 PM
HI,
WHAT timing are you looking to set up, TDC for valve timing using
both pulleys, or ignition which i think from memory, cvh 12 degrees btdc.using bottom pulley, as far as i know all cvh engines are 12,btdc but if efi and setup using crank sensor ecu runs ignition timing. and valve timing done before bottom pulley is fitted forgot it was frst,
Dave.
Old Mar 21, 2004 | 11:46 PM
PJay's Avatar
PJay
That pretty much summed it up mate, you DON'T know what you are doing
No problem, just trying to save you an engine
Old Mar 22, 2004 | 06:07 AM
JesseT's Avatar
JesseT
If you are timing the ignition, you can't.
If you are timing the stock cam, then align both marks.
If you are timing an aftermarket cam, then either measure it properly, or do as above and dyno tune it further.
Old Mar 22, 2004 | 08:14 AM
Windle's Avatar
Windle
FFS alot of hassle over a simple check
cheers for those who actually answered the question i know you cant time the ignition on a FRST due to having no fooking dizzy
i have just rebuilt the whole engine, engine bay converted it from MFI to EFI and basiucally restored everypart of the car alone but i still dont know what i am doing
Glad i looked her too double check now
IainRS1700T
Sep 25, 2015 06:44 AM
gambo08
Fiesta RS1800/RS Turbo
Sep 16, 2015 08:10 PM
bigryrs
Sep 5, 2015 02:57 PM
bigryrs
Aug 28, 2015 05:32 PM
