Cracked Exhaust Manifold - Options?
Old Mar 14, 2004 | 04:14 PM
Default Cracked Exhaust Manifold - Options?
Is there anyway to repair/weld a cracked exhaust manifold? This is off an Escort Cossie. What options do I have? Photo is taken looking into the hole where the turbo bolts on.
John
[/IMG]http://img6.photobucket.com/albums/v20/JohnP007/Garage/Cracked_Manifold.jpg[/IMG]
Old Mar 14, 2004 | 04:22 PM
Dave Henshall's Avatar
Dave Henshall
u could drill each end of the crack witha small drill, grind out the back of the crack - get the manifold really hot (like in an oven) and weld it all back up using a cast iron rod (they do exist) and then back in the oven and let it cool down slowly of its own accord (with the oven switch off) . this should stabilise any expension/contraction causing the weld to crack prematurely.
some more info here : http://www.twi.co.uk/j32k/protected/band_3/jk25.html
Old Mar 14, 2004 | 06:11 PM
dickie's Avatar
dickie
you need to take the / out of the first [img] mate!
Old Mar 14, 2004 | 06:34 PM
Default Re: Cracked Exhaust Manifold - Options?
On behalf on John P
Old Mar 14, 2004 | 08:27 PM
Thanks for the info. A bit out of my league, so will be taking it to an engineering shop so they can have a look at it.
John
Old Mar 14, 2004 | 10:41 PM
THE RADMAN's Avatar
THE RADMAN
they all go there mate,that one doesnt look too bad,ive seen a few with 3 or 4 cracks in them, mines the same,was going to buy a brand new one but was told it would be just the same within a few weeks!
Old Mar 14, 2004 | 10:44 PM
velocity's Avatar
velocity
mine is gone in the exact same place but it gone through to the other side aswell any idea how much a new manifold is
Old Mar 14, 2004 | 11:11 PM
richm's Avatar
richm
same story from me - very common place for a crack - just as you've shown...
is the crack obviously going through to the outside underneath?
IMO, don't worry about it..
Old Mar 15, 2004 | 07:53 AM
Dave Henshall
is this only apply to escos or is it 4x4 saph aswell.
im had both and not had this probelm - am i lucky or could it be cracked and i doent even know?
Old Mar 15, 2004 | 08:03 AM
richm's Avatar
richm
4x4 as well Dave - i gather a lot are cracked in a similar fashion without you knowing - if you never take it apart, you're unlikely to know - the crack often doesn't go all the way through the casting, even if it does it often doesn't 'leak'.
Similar to turbo exhaust housings - cracks are common and often unnoticed.
Old Mar 15, 2004 | 08:26 AM
Dave Henshall
PHEW
Old Mar 15, 2004 | 08:38 AM
Hmmm, might look into getting one of these>>>> Supersprint part number 823201
Old Mar 15, 2004 | 12:04 PM
Just got a price on the above manifold £898.00 including VAT
So, can I run the manifold with the crack? It doesn't appear to be all the way through? I might just chance it.
John
Old Mar 15, 2004 | 01:45 PM
richm's Avatar
richm
yes John, use it, nothing to loose.. it's probably been like that for ages.
Old Mar 15, 2004 | 06:36 PM
You found the cause of the crack yet? on 2wd its pften the failure of the turbo damper/mal adjusted, but the 4wd doesnt have one, any ideas?
Old Mar 15, 2004 | 06:43 PM
richm's Avatar
richm
on the 4wd manifold it is just a thermal stress crack in that position.
Old Mar 22, 2004 | 05:59 PM
Dave Henshall
thought while the head was off today id have a look and whip the turbo off - guess what.....
doh!
Old Mar 23, 2004 | 09:18 AM
I was at GGR the other day and the turbo was off one of the Escort Cossie's, so I had a look, and guess what, that was cracked as well, in the same place.
jessie_rs
62
Aug 6, 2019 09:27 PM
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
steve.rst
Oct 3, 2015 08:52 PM
Si B
Sep 12, 2015 06:49 AM
cossirob
Sep 3, 2015 09:17 PM
