cossie hi revs at idle
Old Apr 4, 2004 | 07:22 PM
Dave Henshall's Avatar
Dave Henshall
Default cossie hi revs at idle
since putting my stg 3 chip in and doing the head gasket on my big turbo escos, now when the car is warm it revs at around 2K with the ISCV connected - when u go to start the car you can hear it click click as it pules and starts fine, ive set the base idle to 950 rpm with it disconnected, but as soon as it is plugged back in it revs up to 2K - the valve must be being told to open by the ecu - what should i check? everything else seems to be ok
Old Apr 5, 2004 | 11:22 AM
Guinnless's Avatar
Guinnless
faulty chip?
Old Apr 5, 2004 | 02:59 PM
Dave Henshall
i spoke to ahmed.....
turns out it could well be the ECT telling the ecu that it is still cold - i have had it dicconnected so might have got it not put back on correctly
Old Apr 7, 2004 | 02:14 PM
Hi I have the exact same problem after the "winter stand still" ????? What did you find out, was it the ECT ????
Old Apr 7, 2004 | 09:54 PM
Thats the problem i've got at the moment, any info would be appreciated
Old Apr 8, 2004 | 07:50 AM
Dave Henshall
no, the ect appears fine - he thinks it might me the KAM on the p8 which cant be cleared by unplugging the ecu - i need a sub loom from ford to clear the ecu faults - my chip did come out of another car so could be holding a fault from that car as mine was ok before i fiteed the chip.
Old Apr 10, 2004 | 11:10 AM
Stu @ M Developments's Avatar
PassionFords Creator
The chip cannot hold a fault, that is done by the ecu.
If its fault induced, you will have a 4Krpm rev limiter now. Have you?
If not, check the TPS is correctly set and of course, plugged in ENSURE teh throittle is closed and the cable isnt overtensioned etc.
Old Apr 10, 2004 | 05:14 PM
Dave Henshall
ah, stu,
what resistance should the tps be set to for idle? i have had it off and put it back in (i thought ) the same place - it has elongated holes so i assume this is how its ajusted...
Old Apr 10, 2004 | 05:55 PM
0.5 to 0.6volts measured at the ecu end.
(300-600 ohms but voltage is a better check.)
Old Apr 13, 2004 | 09:19 AM
Dave Henshall
will check that 2nite - cheers mate
Old Apr 14, 2004 | 07:48 AM
Dave Henshall
it was a little high, 0.76 volts, moved it round slightly so it is now 0.53 at idle. unfotunately it has still not cured it. once warm, it starts fine and idles correctly for about 30 secs, then the ISCV opens and stays open - speaking to ahmed today regarding clearing the KAM of the ecu.
Old Apr 14, 2004 | 01:21 PM
Does your ECU have cold start mapping on it? That might need tweeking if it does.
Old Apr 14, 2004 | 01:36 PM
Dave Henshall
it does - its an off the shelf AB stg 3 chip with pectel board.
Old Apr 14, 2004 | 05:26 PM
Dave Henshall
i thought i'd try and set the TPS right in the middle of its elongated holes - this gave a reading of just over 0.2 VDC from pin 17 at the ecu to ground.
tried it - works a treat now,
cheers for the help guys.
ps, dont know how this might help other with the same problem if they have not been messing about with their TPS - ie was working before storage and is now messing about etc - only thing i can think is the ECT sensor faulty..?
Old Apr 15, 2004 | 09:41 PM
Tony Ryan's Avatar
Tony Ryan
Ive just put my engine together and wonder if its possible to check the tps adjustment before the engine goes in ! They are a pain to adjust normally but mine is worse , a 500 plenum , impossible to get your hand round .!
Old Apr 16, 2004 | 07:27 AM
Dave Henshall
i know what u mean - it is almost imposible to change once fitted - i ended up (on a 4x4 throttle body) removing the throttle body , only 4 bolts and the intake pipe. this might be the easiest way on your aswell, but i think on a 2wd red tps you need to set it so the resistance is infinate at idle.
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
fordrallycar
Sep 30, 2015 07:57 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
