cossie misfire
Old Mar 10, 2004 | 10:33 PM
Default cossie misfire
Got a misfire on my 2wd saff between 3750 rpm and 4250 rpm.Changed the plugs for pp8's and gapped them 28 thou' then gapped them 25 thou' but still no joy.Sometimes it doesn't do it other times it does,plugged it in to my mates crypton tuner to make sure the coil and leads etc were o.k. and seem fine.Took dis cap off to check and rotor arm but all appears fine. Car is also running a stage 1 chip,never had a misfire on it before at all in four years of ownership so this is really strange to me.Any ideas guys?
Old Mar 10, 2004 | 11:40 PM
PJay's Avatar
PJay
Check phase sensor gap and wiring and crank sensor gap, what boost is the car running?
Old Mar 11, 2004 | 07:34 AM
The car is running 14 lbs of boost,what is the correct gaps for these sensors?Its a G registration,the mixture on tickover is 2.6% which seems right to me for a stage one conversion
Old Mar 11, 2004 | 08:21 AM
check the ends of the leads for the plugs. if they havnt been fitted properly they will burn off. Especially on a performance engine. I go thorugh a couple of leads every month or so!
Old Mar 11, 2004 | 09:13 AM
Checked the leads and ends before and they're all good.
Old Mar 11, 2004 | 02:23 PM
PJay's Avatar
PJay
You need to get some proper leads then
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
