cossie 2wd water pipe running
Old Mar 10, 2004 | 01:33 PM
Default cossie 2wd water pipe running
help just put the car back together and cant work out where the water pipe that comes off the metal pipe that runs under the rad.It is about an inch diameter and there is no where for it to go that i can see.The way i run the other are
header tank to rad
header tank return to turbo
oil cooler to heater matrix
oil cooler to head
and then just the easy bigger hoses
please help
Old Mar 10, 2004 | 02:19 PM
The only other pipe mate is rad to water pump
Hope that helps.
Old Mar 10, 2004 | 05:11 PM
Toe Knee's Avatar
Toe Knee
As said the one that comes off the metal pipe, one end goes to the rad, the other end connects to the water pump which is on the block.
Old Mar 10, 2004 | 07:05 PM
yer but the water pump one is running from there to other heater matrix hole
has any one got any drawings or diagrams
Old Mar 11, 2004 | 07:24 AM
Heater Matrix has 2 ports, 1 goes to oil cooler as such, the other connects to the metal pipe which runs along the manifold to the thermostat, water pump has another t off to the bottom of the rad. Thats all i no off.
Have u got a 2wd or 4wd thermostat housing???
Old Mar 11, 2004 | 07:39 AM
Toe Knee's Avatar
Toe Knee
If your water pump doesnt have an extra outlet for the pipe that goes to the rad then you have a 4x4 water pump not a 2wd one as on the 2wd the pipe that goes to the pump actually goes to an extra outlet on a 4x4 stat housing!!
blackbeautyzetec
Aug 29, 2015 02:11 PM
David Potasnick
Ford Fiesta
Aug 22, 2015 10:54 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
RsS2daz
Aug 14, 2015 05:26 AM
lockie
Jul 31, 2015 10:03 PM
