- Removing a Focus RS Driveshaft
- timing help
- 2.1 ZVH Head gasket and bolt options???
- Saph Cosworth 2wd Diff fluid & gearbox fluid ???
- 1.8 duratec he
- Sport ka issues
- head querys
- Rear panel for Sapphire
- FAO engine tuners - spark map advice needed.
- 4x4 wheel offset
- cozzy 4x4 to 2wd
- Escort RS Turbo Starting Problem And Oil in the Intercooler
- xr3i mpg?
- water cooled turbo plumbing??
- Sapphire Cosworth Rear Shock Question
- Series 2 RST clutch and flywheel on mk2 XR2?
- escort back box
- Sierra Cosworth T3 Turbo Housing (cracking)
- secs s8
- mk4 escort rear inner arm bush
- stage chip graham Goode "l2v2red.mot" ?
- swirl pot lift pump......
- escort mk4 bolt on wing conversion
- t3/t4 turbo on a 1.8 zvh?
- Final drive ratio
- co2 adjustment
- My Gearbox in my mk3 escort rs turbo cabriolet has gone.......
- Escort MK6 Convertible Relay? Fault Finding
- I need info for The gear ratios for Front wheel drive
- Help identifying loom connection
- cossie brakes on escort mk4
- t3 refurb
- 3dr or 5oo head
- cossie oil
- 5bar map sensor for omex 600
- escort stuttering spark plug gap??? help???
- torque settings needed
- Coswoth smoking .......
- stupid question
- Focus ST brakes on a 1.6 Focus
- help with fiesta mk3 xr2i 1800
- st170 head?
- Cosworth conversion
- whining sound
- rover injectors 220 420 820 800
- help needed s1 ecu colour codes
- abs problems
- cab suspension
- Sierra mirrors....
- Midlands garage to set up my series 1
- Escort Mk5 Cab problems
- Series 1 RST Turbo advice
- mondeo v6 ghia radio
- HELP - XR2i 16v rear brakes
- Slicks on 18s
- ignition timing erst
- quick brake question need urgent answer
- how can i ???
- fiesta coswrth brakes
- mechanical tempeature senders
- this may sound dum
- 6 Pot or 4 Pot..?
- Airbag Contol Module Replacement
- HELP.. Adjusting Torsion Bar
- s2 rst probs
- zetech clutch
- IDS when did it come into play?
- throttle position sensor voltage
- Type 9 box - replacing gaskets
- zetec revvvvving
- st170 problems
- porting / polishing
- N/A tuning zetec
- escort mk 4 van project
- Focus RS boost
- Fiat bravo flat batt !
- rs turbo cills and floorpans
- xr3i engine with carb wiring problem.
- Fiesta turbo inlet pipes etc HELP
- Efi inlet on zetec turbo
- Kent cams valve springs on zetec turbo???
- Megasquirt+CVH EFI and IACT valve. Idle problems
- rs turbo camshaft what make is it
- Few rs turbo questions.
- using a 16I inlet manifold for zetec turbo??
- eec4 cozzy green fan relay?????
- 2.0 PINTO
- Xr3i 'Pinking'
- Group A Escort MK 3
- Sierra P100 1.8td diesel Flywheel and Ring Gear Replacement
- mk4 escort zetec upgrade
- Fueling prob with s1
- P Reg Mondeo Indicator Bulb...
- bucket seats
- Turbo porting????
- Straightened YB crank?
- problem with xr2 mk2
- st170 crank max rpm
- escort cozzy eec4 fan relay location????
- cosworth brakes
- megasquirt db37 plug
- Garret hybrid T4 problems...
- Lambda for pectel t6
- Fiesta Front wheels not pointing in the same direction!
- problem
- top hose i/d fez rst
- missing when starting up
- Mk3 fiesta electric window switches, help!!!
- Removing the ABS system on a Mk4 XR3i?
- mondeo mk3 bonnet release help
- cvh to zetec conversion advice wanted???!!!!
- Can anyone tell me what an RS Part is for from the number
- escort gti tuning
- What size brake pipes and connections for a saff
- is this true?
- mk4 escort carb problem urgent help needed
- Fitting 4x4 mounts to 205 block
- Zetec turbo Block Oil adapter
- Any difference between a Escort XR3i and RST fuel pump?
- fiesta oil temp?
- Back suspension bushes on a mk2 orion
- standard sapph cd player
- Cosworth injectors
- best loom to use for a 2.0 zetec conversion
- fitting a fse valve
- external wastegate plumbing
- which gearbox oil?
- Chrome exhaust pipes for Mk4 Mondeo
- Piston differences
- focus rear brake calipers
- RS1600I Question
- clutch
- What Resistor For A 8mm Red Led?
- 3i, RST MFI
- linking clifford alarm to central locking, ERST S2
- external wastegate fitting advice
- frst engine help
- xr2i/rs calipers/pads queries with pics !
- front bumper
- another way to lower compression ratio?
- Ford Ka Engine Problem
- Thread size for BC gearbox oil plug
- sideskirt clips
- megasquirt
- still have a spark problem
- ECUs again!
- YB/Zetec Valve material/construction
- Diagnostic code help
- Cosworth bore size??
- CVH 1.6 carburettor Spark plugs
- central locking fitment, S2 ERST
- s2
- last pointers on rear disc conversion
- removeing door pins
- rev counter wrong on zetec turbo
- st 170 head cc
- fitting a new seat bolster
- Clutch Slipping?
- miss on big power escort cosworth input needed
- MK3 Escort Cabriolet speaker size?
- Compomotive alloy wheel Help!
- NOS solenoid frequency's
- turbo chargers
- where exactly do i check my lambda on the ecu pins
- Zetec Engine problem after -20°C and dead battery
- Ford Focus
- Mk6 zetec turbo
- electrical problem
- Zetec exhaust stud thread size?
- Turbo water coolers
- Camshaft HELP!
- 1986 escort rs turbo wont start
- Ecu hellp were can i find it on a focus 05
- coloured connectors
- Diff ratio ?
- cosworth rear axle on a p100
- Boost control on saph please look & help
- :'( engine wiring loom gone up in flames
- no fuel pump relay???
- how to set boost cosworth
- KA bumper how to fit?
- Zetec Fail -help needed please
- Ahmed Bayjoo springs- sits odd??
- Zetec questions
- 4wd front brakes - will they fit a 2wd?
- omex ecu hard to configgure to laptop
- drive shaft problem
- 2wd Sierra Cosworth Front Indicators and Oil.
- help
- Misfire on ZVH
- Ford Ka door panel removal.
- Engine & Gearbox
- edis module compatible??
- seriously rich cossie
- what size disks can i fit inside 17's?
- various technical articles available for download.
- Removal of 54 Plate VW Polo tailgate trim
- Boost gauge....where do I connect it to?
- Cosworth panels
- wiring trouble
- sierra disc?
- oil leak!!
- zvh
- Big power 1800 diesel?!
- Cosworth manual needid
- xr2i/rs turbo side strips?
- Battery Light On Constant ERST
- two head gaskets?????
- cutting / reconnecting fuel lines
- Engine Swaps - DVLA, MOT, Road Tax
- Rotar arm removal
- Mondeo '05 2.0l TDCi glow plug light flashing
- Granada Scorpio 4x4 gearbox?
- Gettin 2 Psi of Boost at 5,000 RPM :(
- Focus RS lump in my Orion
- Brembo 4 pot calipers
- Focus Brembos under 16 inch MO's?
- How to remove a Focus Fuel Filler Cap???
- fiber glass kit
- outer tca bushes & rack
- mondy 2.0 zetec hot start probs
- 2.0 zetec front breather??
- Escort RS Turbo with FRST engine and loom need help, running badly
- vw problem passat will not rev above 1200 rpm
- zetec inlet manifold
- st17o or foucus rs clutch in my silver top engine
- 4 to 5 stud
- FRP whining
- plenum spacer
- ERST Problem! Fuel Delivery Possibly?
- Fitting Omex rev limiter to efi rs turbo
- fuel pumps
- cozzy 4x4 tappet noise... still
- Sierra Cosworth Wheel Offset
- Cossie rep wheels
- st 220 water pump
- mahle piston identification ???
- How do you set the emissions on a cosworth?
- tabbetha twin coils
- How to break into a series 1 RS??
- RS Turbo Feels Hesitant :(
- Roof Rubbers and locking latch
- tabbetha coils
- No Boost
- STILL SMOKING....Cossie
- tabbetha..coil coversion
- black top zvh turbo
- turbo re-con
- ARP rod bolts...
