1.8 duratec he
Old Mar 19, 2009 | 08:34 PM
twister's Avatar
twister
Default 1.8 duratec he
A friend has got a 55 plate mondeo 1.8 Duratec he in the garage? Bit of a strange one here's abit about it.
It run's fine until it goes over 30 degree's in engine temp and gain's a misfire when it reaches around 60 degree's engine temp you can rev through the misfire.
Powertrain control module as been tested o.k
Lamba's sensors and readings are good
There is no fault codes at all
Compression tests were
cylinder 1&2 185 psi
cylinder 3&4 210 psi which are quite high
Any help would be great
DanDMC
33
Oct 7, 2015 01:58 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Iain Mac
Sep 30, 2015 09:39 PM
talon1
Sep 15, 2015 10:27 AM
