timing help
Old Mar 20, 2009 | 09:52 AM
trebor's Avatar
trebor
Default timing help
i know its not a ford but does anyone know how to set the timing up for a 98 vectra 2.0 16v? its the wifes motor her dad took its to bits without knowing what he was doing while i was waiting for the new oil pump to come.
thanks rob
Old Mar 20, 2009 | 10:17 AM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
aline the timing marks on the pullys the 2 cam pullys and the crank and fit the belt keeping the thrust side tight of corse
Old Mar 20, 2009 | 11:48 AM
IANS2RST's Avatar
IANS2RST
try on migweb or the vectra owners forum. iirc when u take the bottom pulley off there is an indent in the belt pulley that lines up with a notch & the 2 pointers on the cam wheels go vertical lined up with the notches on the cam rocker cover. its an autotensioner & the pointer on it needs to be alighned correctly so it willl tension right - can't remember that bit though
Marino
Sep 12, 2015 11:10 AM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
