cosworth rear axle on a p100
I thought the P100 was a solid rear axle ?
If so mucho fabrication needed as the cossie set up is independant suspension, so diff is mounted to body and has a shaft each side that move independently of the diff, so diff would need suspending, location points for dampers, springs, hubs/arms etc would all need sorting.
yea the p100 is a solid rear axle but ive seen a few advertised for sale with it done
think there was on here a bit back
if anyone has any pics of it done let me know cheers / or a rough idea of what needs doing
09-10-2015 07:38 PM
TrevCos
22-08-2015 06:05 PM
assembly, axle, cossie, cosworth, diff, ford, independent, indipendent, p100, rear, sale, sierra, solid, suspension, suspention
