PDA
View Full Version : Technical help Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114
  1. st escort cos sparkplug cover
  2. Gear box
  3. ZVH RST Running Problems
  4. supercharging a focus
  5. wiring diagram needed help!
  6. Pistons
  7. Thermostat
  8. I dropped a hub today and broke a lug mount
  9. removing an alarm & imobiliser
  10. 1.6cvh + 6 speed st170 gearbox...
  11. clifford concept 450 g5 mk1 i think
  12. help, advice, opinions il accept all
  13. RS Turbo Single Wiper Conversion
  14. Cosworth auxilary pulley bolt size
  15. Crannking voltage
  16. another radio code thread
  17. Smoke ring's on idle
  18. Plz hellp my car is doing my head in
  19. power steering on fiesta mk3
  20. problems yet agen!
  21. head gasket???
  22. ofab not working
  23. Which head
  24. Saph dash
  25. Anyone know how to time rs turbo correct and firing order, won't start
  26. s2 rst boost problems
  27. Turbo to Airbox Pipe help needed for 2wd saph!!??
  28. hesitating
  29. Wrinkle paint
  30. turbo boffs
  31. Mk5 escort engine transplant
  32. Focus MK1 Head Unit Issue
  33. rs rear beam
  34. escort rs turbo starting problem
  35. Escos tb onto sapph
  36. Pectel P8 engine loom
  37. focus rs over boost problem...
  38. efi curious
  39. 1.3 fiesta running poblem
  40. mk6 Escort van heater matrix
  41. Stage 2 on a t2
  42. Best plugs and leads for a ST170?
  43. Refurbing wheels?
  44. Mondeo misfire
  45. Cossie valve heights
  46. Convert escort van to td
  47. fiesta (zetec) clutch problem
  48. smoking turbo diesel
  49. ecu problem
  50. smoking 2wd cossie help
  51. cvh oil pump ?????
  52. zetec head question...?
  53. XR2 door poppers
  54. head unit / cd player wiring
  55. RS Turbo ECU Help
  56. Escort, What carbs to go for??
  57. Removing Rear Piston From Caliper
  58. 4x4 saff misfiring
  59. Can any one help
  60. 1.6 cvh into a 1.6 cvh turbo
  61. Help with exhaust fitting
  62. Are these 4x4 or 2wd cossie brakes?
  63. 2.0 conversion, PATS help
  64. mfi converting 2 efi .. core plug??
  65. Heater probs
  66. please help..xr2i 8v fuel pump on any other ford?
  67. Carb CVH Compression ratio
  68. xr2i horn relay????
  69. Same Fuel Pump As A Xr2i?????
  70. is there such thing
  71. Couple of questions about running gear...
  72. problem on 99 fiesta
  73. gearbox ratios
  74. fuel pressure
  75. Horn relay?????
  76. fitting a window
  77. -31 or -34 for a 3 door coz?
  78. cant get the car to start :(
  79. Whoops!
  80. 2006 Focus C-Max suspension upgrade
  81. wireing for gauges lights
  82. Confusion over XR2i engine
  83. mk4 escort ignition wires help
  84. cossie brake sensing valve??????
  85. xr3 on twin 40s????
  86. fitting a t3
  87. help wiring problems!!!
  88. backfiring problem!!!help
  89. efi fusebox
  90. OFAC IAT sensor??
  91. cheap or genuine?
  92. zetec tuning
  93. Lowering escort van mk6
  94. Changing the oil (my first time) *changed, but...*
  95. r nd gearbox
  96. toad window Closure PWC 402
  97. mk3 escort street sleeper...suggestions
  98. do i need adjustable pullys
  99. Should i Be Knocking on 300bhp???
  100. Problem With My XR2I
  101. Trying to sort my missfire on the 3dr...
  102. sapphire cosworth 'hunting' bad idle
  103. which engine route to go down cvh efi,zvh etc
  104. changing ignition/locks (1996 Escort)
  105. Why does my rst over boost
  106. which cosworth head to use?
  107. cosworth mixture screw
  108. t4 or t35 on my cossie
  109. Aeroquip Fuel Lines
  110. P.I Dampers? what's the crack with these
  111. Fiesta RS Turbo OFAB Running Fault
  112. Escort van rear discs?
  113. car locking help
  114. ACT Sensor S2 ERST
  115. Changing front lower suspension arm on Courier Diesel
  116. no 2-4-reverse gear
  117. efi turbo boost guage
  118. Frst head
  119. Bootlid Problem on a 53 Plate Mondeo TDCi?
  120. Fiesta Mk3 Fuel Cap/Neck
  121. Need Help On My XR2I Please
  122. 2.5 V6 Duratec
  123. Puma ABS/TC problem
  124. 1.6 x-flow,kent 244 cam,1300 pistons
  125. Fiesta Rs1800
  126. 3-door rear beam
  127. cossie boost
  128. I need a bolt ?
  129. 3dr intercooler
  130. which gel battery will fit?
  131. Cosworth mk2 won't start
  132. Fitting my cd player..
  133. will a 1.8 zetec head fit a 2lt zetec
  134. Non starting RST
  135. Cam lobe tolerances
  136. Custom stainless exhaust CVH
  137. Xr2 clocks to S1 Rs clocks?
  138. Xr2 Fuel Pump? Advice?
  139. water injection pump suppliers
  140. Any idea what car this is from ?
  141. Heat wrapping exhaust manifold
  142. RS Turbo Problem. Help Needed !
  143. Loss of dash and rear night lights?
  144. mk6 escort rev counter not working properly after efi conversion
  145. T34 or T3?
  146. ST170 IMRC motor question!
  147. throttle bodies and tps probs
  148. Stage4?? Cossie miss fire
  149. tapping noise from engine on zetec s w reg
  150. Can i swap or not
  151. Boost controller help
  152. 5Th gear puller and ib5 gaskets
  153. What monitoring equip is needed for live mapping
  154. cossie 4x4 smoking
  155. Setting verniers (sp)
  156. running problem
  157. 1.3 pop to xr3i clocks
  158. Saph exhaust Q??
  159. help 2 litre pinto injection efi
  160. 1800 cvh inlet
  161. Mk6 Escort Van Lower Arms
  162. Fuel cut off mk4 escort cabriolet?
  163. loud knocking from n/s/f wheel
  164. help
  165. sierra 4x4 cosworth front cross member ?
  166. Puma Racing Brakes
  167. hello help with my brakes
  168. Mk4 Fiesta Electrical Problems
  169. Sierra Sapphire Fuel level sender ohms
  170. Cossie 4x4 Exhaust & Inlet Manifolds or 2wd??
  171. cossie long stud nut socket.......
  172. How do i repair the fuel guage on a 99 focus please?
  173. New here and advise please
  174. 1.3 popular to rs turbo
  175. how to make a flamer kit d.i.y ??
  176. 2 button to 3 button
  177. Converting to efi
  178. CVH wide cam belt
  179. HELP!!! core plugs have cum out!!
  180. Group A coil on CVH not turbo
  181. escort mk 5 handbrake
  182. Problem with RS 2000 4x4 viscomatic coupling
  183. door locking
  184. Cvh timing info
  185. engine problem maybe I have valve rebound in my CVH?
  186. L.s.d gearbox
  187. Loud rattle from front passenger side wheel/suspension
  188. steering wheel grease
  189. Turbo Technics sierra dohc needs help
  190. Cossie noob questions
  191. kent or piper????
  192. cossie plug gap
  193. arp stud & nut kit for 1.6 cvh escort rst
  194. zetec bottom end onto a 1.6 frst
  195. frst block cracked
  196. thermostat?
  197. my 1st post
  198. any advise? boost problems
  199. st escos headgasket part number?
  200. mk5b gear linkage....
  201. Zetec black top into a Mk4 escort
  202. chassis rails (front)
  203. Wishbones again.
  204. t2 or t3
  205. Steering Spline Question
  206. cos gearbox
  207. newbie question
  208. bike carbs on cvh
  209. radio remote
  210. bd14 for 500bp?
  211. rs turbo engine frozen over night
  212. What are the best HT Leads & Plugs For MK4 XR3I EFI?
  213. help
  214. Focus MK2 Fuel consumption
  215. Puma/Fiesta interchangeability
  216. PRESSURE
  217. t34 stripdown
  218. pats wiring problems on an RS2000 engine
  219. does the saff coz petrol tank fit the 3dr coz?
  220. ecu problems
  221. New Diff fitting...
  222. starts then dies a few seconds later
  223. WIRING
  224. Car not re-starting when hot, why???????
  225. mk4 efi escort running problem
  226. escort caliper identification
  227. cam timing yb
  228. zetec bhp question?
  229. Couple of Q's for you
  230. cossie plus in rs turbo?
  231. Escort wiring
  232. help how to lower the arse end of my escort van on leaf springs
  233. xr2i horn not workin
  234. ford focus warning light
  235. Focus pulling to the right
  236. saph bd14 cams and standard springs an tappets???
  237. Heater trouble (saph 4x4 cos)
  238. How to be sure that my lambda does NOT work??
  239. Camshaft replacement
  240. zetec oil cooling
  241. focus edge
  242. could a welded diff cause this???
  243. Diesel escort cold start (setup?)
  244. oil pressure switch
  245. 2.0 zetec wont run
  246. Cortina and Capri Diffs
  247. zetec tps
  248. s2 starting and boost hesitation
  249. converting CFI to MFI
  250. Hunt the Starter
