Smoke ring's on idle
Old Jan 26, 2009 | 01:26 PM
Rs Cosworth 1's Avatar
Rs Cosworth 1
RS for life
Default Smoke ring's on idle
Hi i'm a newbie here sorry i tried to search for it.
I have a saffy cosworth 2wd stg 2 engine making 272hp it has 100k engine is pretty sweet pulls excellent etc made a load of smoke when i ripped her open when i first got her not much if anything now,
But on idle it seem's to misfire but not bad misfire just like the throttle is open then closed as th rev's are up and down ad after that it starts to jump like a little misfire every so often and smoke rings are coming out of the exhaust???
Any idea's sorry again if this has been answered but i just wanna sort it out!
P.S the idle is rough quite rough TBH
Thanks,
John
Old Jan 26, 2009 | 01:47 PM
jemis's Avatar
jemis
probably a dodgy sensor making it overfuel, what colour are the smoke rings
Old Jan 26, 2009 | 01:49 PM
Rs Cosworth 1
RS for life
The smokes white but thats probably the heat of the exhaust and the cold,
The rings just puff out with the white smoke!
Thanks.
Old Jan 26, 2009 | 05:01 PM
Rs Cosworth 1
RS for life
Any one got an idea on the sensor or where to start at cos this is my first cossie so any help appreciated!
Thanks
Old Jan 26, 2009 | 05:22 PM
col93saphcos's Avatar
col93saphcos
on my 4x4 noticed alot of smoke rings one day,not noticed it recently,but just before ring was like a slight pop from exhaust,hardly hear it,was running fine so never looked into it,thought it was pretty cool!lol
col93saphcos
Old Jan 26, 2009 | 05:25 PM
Rs Cosworth 1
RS for life
col93saphcos
Thats what mine is doing popping the poof a ring!
Old Jan 26, 2009 | 05:37 PM
bamba's Avatar
bamba
i had this one mine.i replaced coolant temp sensor as there was a slight hesitancy when starting,but also replaced the plugs and it was this that stopped the smoke rings.hope this helps.it was almost as though the car would have an occaisional hiccup as it was idleling. cheers GLYN
Old Jan 26, 2009 | 05:49 PM
Rs Cosworth 1
RS for life
Thanks folks will start there then cheeRS
Steve Escos
Oct 1, 2015 06:57 AM
fordrallycar
Sep 30, 2015 07:57 PM
deathrider666
Sep 28, 2015 06:12 PM
