What monitoring equip is needed for live mapping
Half Rice Half Chips
Can anyone help,
what monitoring equipment is needed to live map a car bnar the software & laptop.
Any help would be great
Depends on what you want to do. If you want to map for power then I suggest using a rolling road or alternatively an engine test bench.
Usually these people will have all the right tools to monitor the engine.
well then engine will be a fresh build and installed inthe car, I would like to have a god at mapping the car with more boost, just trying to see what is envolved and what parameter I need to learn, I dont have access to a rr so the open road it is.lol
Is it obvious to tell from det cans if its pinking? what does it sound like
My 4 part live mapping guide should help you understand what goes into a Live map. I have attached all four parts. Please feel free to download them for free.
Any problems, they are also hosted here.
Last edited by Stu @ M Developments; 14-01-2009 at 10:18 AM. Reason: Fat Fingers...
*** Sierra RS Custard ***
What ecu does your car have?
Stu thanks for that help mate its much appreciated (its Raj from Autoflock by the way)
Chip, it is a Gotech MFi pfo x, been speaking to Simon at Sitech and he is doing the base map for me, just interensted in having a go myself after I have ran the engine in
Ive not personally mapped anything on gotech, but looks pretty straightforward software etc, im sure that will be a good starting point to learn from.
Start by trying to get it to do 14.7:1 on the light load sites with no closed loop lambda and it will be good practice without really risking anything melting.
cheers, I think I need to research into what each of those figures means.lol, im going to set the boost to around 1 bar, maybe 16psi?? im after the magic 200bhp+
ive seen a bloke called garage19 make some of these and I can see some in stu's article, look proper gay but if they help stop me blowing the car up then so be it.lol
Am I correct in thinking its just ear defenders and tube bolted to the head somewhere???
i want some det cans too and just re-read garage19's article. he discusses using good ear defenders to screen out other noise but what is good? the prices seem to range from Ł3 - Ł10. are there any recommended electronic options available which could be permanent install?
Pasted from my installer area:
As you know, knock can be potentially devastating to an engine, so we have here some equipment that can be used to detect knock.(detonation).
The KnockBox Single Channel - Ł345 + VAT
THE KNOCK BOX comes as standard with a headset, sensor and wiring loom:
Single Channel KnockBox
- Single knock sensor
- Single sensor sensitivity adjustment
- Mono listening through headset
- Dual overall volume control on headset
- Aircraft quality headsets
- Passive noise canceling
- Dual volume controls
- Foam ear pads for ultimate comfort
- Bosch knock sensor
- OEM Factory quality
- Easy lock Utalux connectors
- OEM quality loom
- 3 Core shielded cable for sensors
- Molex connector
- Cigarette power supply
2009 Price has yet to be confirmed though.
More or less cost Stu. Thats lots of dosh and looks like a proper peice of kit for pro's to use. Is there anything less expensive?
That said, I got my knock box off stu a year ago, its never gone wrong, the headset is comfy, it has adjustable volume on each ear, its got a nice quality feel to it, and I cant fault it.
For a serious user who is doing it a lot, I think its a fairly good option, but for occasional use, you could easily spend half the money and still get something good enough.
And being totally honest, for doing ONE car, Id go for manual det cans anyway, they work better in terms of clarity of sound IMHO, they are totally reliable, and are cheap to make, they're only downside is not being convenient to go from car to car with.
You need to take into account that someone like stu will probably map it in half a tank of petrol to your 2-3 tanks as a beginniner too, so thats anothe 100 quid gone.
That said, i'd say you should have an AFR gauge anyway, and if you make your own det cans they are cheap, so on that basis its not so bad.
But do bear in mind you may well excessively det or borewash the engine, which means building a new one, lol
The exact reason I didn't road map my megasquirt myself, no knock detection... I'm hoping someone at work can help me out now... Good luck with it all!
JAmes.
JAmes.
big_Rad
15-09-2017 09:36 AM
