Why does my rst over boost
Old Jan 17, 2009 | 06:33 PM
leejones09's Avatar
leejones09
Default Why does my rst over boost
it only ever does it in 5th gear when i put my foot right down at about 2k rpm it idles perfect starts fines and it pulls great all the way up the range if you floor it in second it will fly up the rev counter unless its wet it just spins will it be ok cheers in advance all
Old Jan 17, 2009 | 07:05 PM
siward's Avatar
siward
Do you mean boost cut?
If its boosting ok in 1st and second and sometimes 3rd and cuts in 4th and 5th, It means you are running too much boost for the standard ecu if its not chipped.
Si
Old Jan 17, 2009 | 11:55 PM
leejones09's Avatar
leejones09
yeah thats what its doing but it holds boost in 4th an 5th if at higher revs
Old Jan 18, 2009 | 09:08 AM
siward's Avatar
siward
It will do mate, I had the same problem before, Just turn down the boost or get it chipped and set up.
Si
timsrs
Nov 13, 2018 11:48 AM
A.t.p
Oct 23, 2015 07:54 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
