ecu problem
Old Jan 23, 2009 | 01:28 PM
dazzaj's Avatar
dazzaj
ps3 name.. LYNX-79
Default ecu problem
can any 1 help.. ive 3 wires that connect up 2 the PATS system.. the connection is near the ecu.. witch is a beau ecu.. 1 wire connects 2 pin 55 on ecu and the 2nd wire goes 2 pin 56.. these 2 wires then lead 2 the crank poss sensor.. the 3rd wire just leads 2 a un-connected plug in the engine bay.. im tryin 2 get the engine runnin, with no luck.. is there a way 2 by-pass this 3 pin plug??
Old Jan 24, 2009 | 12:37 PM
dazzaj's Avatar
dazzaj
ps3 name.. LYNX-79
Default ??
o.k no help with that 1.. ive still got the PATS sysyem with this ecu includin the chiped key.. i can plug it into the 3 pin plug ahd she still won't fire up.. theres another plug further up the system with6 pins in it.. i know a few wires went 2 the fuse box witch has now been thrown out.. a few went 2 a siliver box whch says rly asy-door lock control.. so my question is can i by-pass this 6 pin plug?? i know that the key and key sensor have 2 be together.. plz help, as this project is now a wk over due...
DixieTheKid
11
Jun 6, 2020 11:20 AM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
tib2220
Sep 14, 2015 12:33 PM
dms04
Sep 11, 2015 01:57 PM
