How to be sure that my lambda does NOT work??
Old Jan 3, 2009 | 07:04 PM
JanDK's Avatar
JanDK
Default How to be sure that my lambda does NOT work??
Fitted a new chip/cloosed loop to my car .. Escort Cosworth.
Because my last chip was a very generous fuelling chip I havent been concentrating so much on the economy and if the lambda worked ok.
My question is about if my lambda sensor is dead or not...
I will not see anything like 14-14.3.4.5.6.7 afr when cruising with lambda connected (tried 3 used lambda sensors) when disconnecting my lambda my afr figure drops from about 13.5 to about 12.2-12.5. The same sort of drop in afr happens at idle and normal/no load driving.
Can a lambda sensor be out of order, but still working but "just" being out of range, not regulating enough??
How can I be sure that the lambda is working CORRECT.. or not?
Another thing is.. can a lambdasensor tester check a lambdasensor 100%, and how does such a tester work??
mint_s2
Sep 2, 2015 08:58 AM
Dahl88
Aug 22, 2015 08:16 PM
RsS2daz
Aug 14, 2015 05:26 AM
