Pistons
Old Jan 27, 2009 | 08:42 PM
woolford's Avatar
woolford
Default Pistons
can pistons be polished an refit into an engine???
Where would i get this done and rough price???
Thanks Paul
Old Jan 27, 2009 | 08:45 PM
B16CVH's Avatar
B16CVH
What do you mean by polished??
You can re-use pistons once cleaned and if they are NOT badly worn around the skirts/little end diameter.
Old Jan 28, 2009 | 11:57 AM
woolford's Avatar
woolford
i mean polished up really shiney bling like a new set would come..
Thanks
Old Jan 28, 2009 | 12:05 PM
RS 5tu's Avatar
RS 5tu
it depends. if the piston had a bigger gudeon pin like XE pistons for example you can modify the conrod to accept the bigger pin but if you have a set of pistons with a smaller gudeon pin then i dont see a way around it. Not to mention the CR as your new rod & pison combo may now be too tall and hit a valve or too small and give a crap CR
Old Jan 28, 2009 | 12:08 PM
LHD220Turbo's Avatar
LHD220Turbo
Thanks Paul
if your rebuilding a motor why bother? just buy new for peace of mind
do it right first time rather than piss about with used pistons
Old Jan 31, 2009 | 08:58 AM
jammy86's Avatar
jammy86
You can polish the tops which offers some thermal advantages, however do not touch the skirts with anything heavily abrasive as you might take off a small amount of material and change the skirt to bore clearance which might result in piston slap.
JAmes.
Old Jan 31, 2009 | 06:16 PM
westus1's Avatar
westus1
if its just to make them shiney then dont bother as a small corbon build up can actualy improve he piston seal and cylinder leakage
if your pistons/bores are even slightly worn then i'd say renew,
best to only do it once, do it right 1st time then forget about it
if you gotta keep stripping it down you'll get sick of it and want rid of it
Nov 1, 2015 06:53 PM
little bram
Oct 4, 2015 12:13 AM
deathrider666
Sep 28, 2015 06:12 PM
timsrs
22
Sep 24, 2015 08:14 PM
ajamesc
Sep 8, 2015 06:51 PM
