PDA
View Full Version : Technical help Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114
  1. MTX75 gearbox is it a front wheel drive box
  2. cosworth cylinder head
  3. Escort mk4 wing replacement.
  4. Ford focus
  5. p1518 problem
  6. 2.0 zetec turbo conversion into a mk4 erst
  7. Rs2000 van conversion wont idle properly and cuts out under acceleration?
  8. Focus abs help
  9. 2002 Fiesta Endura-e J4J over revving and TPS dtc code
  10. focus st225 electrical probs
  11. ib5 bell housing swap
  12. series 1 bulb types
  13. Focus rs mk2 flutter
  14. furl tank prob
  15. Transit t350 75 ps
  16. Help with naming a pipe mk2 1.8tdci
  17. Focus st headlight help please :)
  18. cosworth ecu plugs same as anything else?
  19. Need help identifying 2 parts
  20. zetec turbo wiring
  21. mk5 fiesta idle issues
  22. 2nd throttle return spring- HELP!!!!!
  23. mfi xr3i to efi turbo querie
  24. Ford Ka Battery Drain
  25. Escort MK6 Stainless Steel Exhaust?-Advice Needed
  26. Ford S Max
  27. Focus turbo help
  28. Knife edging cosworth crank
  29. Blacktop turbo
  30. Turbo charging st170 motor
  31. Mk4 escort MTX info pls
  32. f super formidable software
  33. battery light glowing mk3 escort
  34. AP 6 paddle friction plate
  35. another transit connect abs light
  36. Fiesta ST gearbox
  37. Oil pressure and oil temp problems
  38. what 15's have largest id?
  39. Idle drop when warm
  40. DTA E48 cosworth map
  41. stage 3 = stage 1
  42. LED brake light
  43. V6 12v 2.9 sump gasket same as 2.8 sump gaskets?
  44. Fiesta st fuel pressure
  45. Escort mk6 1.8 alternator removal
  46. temperature gauge
  47. Help with T3 ID
  48. Zetec engine code
  49. 1.6 head on 2.0 efi pinto
  50. l8 ecu no power
  51. tddi problem
  52. L8 Pectel Super 8 Engine Management Loom
  53. Zetec turbo timing belt
  54. Help Electrical Problem :(
  55. indicator relay info needed
  56. What oil to use when running in my yb
  57. Space heater help
  58. 1.4 cvh not starting, nothing there at all.
  59. cosworth original 4wd lambda sensor wires?
  60. Revs drop off advice please
  61. Denso question
  62. Sapph cozy rear window rubbers
  63. Subframe bent upwards?
  64. Cosworth ABS
  65. welding my mk3 fiesta
  66. s2 rs turbo
  67. Mk4 Escort 1.1 Xflow to 1.8 Zetec help please
  68. T3<>T34 turbo
  69. Ford Focus RS Sony Head Unit
  70. Focus MkII TDCi EGR fault
  71. where to get resonable new parts from
  72. looking for a mobile welder birningham?
  73. Mk4 Ecsort cab battery light
  74. Ford focus fan stays on
  75. cosworth setting up surrey
  76. Engine swap.
  77. s2 escort heater going cold
  78. Help! Advice on engine swapping
  79. Granada Dash Clocks
  80. s2 rs turbo battery wire help
  81. Maintenance fiesta 2007 1.4TDCI
  82. cut back blades
  83. Two old alarms need removing.
  84. 1998 escort 1.8td engine/start problem
  85. St170 gearbox in a 1998 focus 1.6 estate
  86. Try not to laugh!!
  87. ford transit mk5 fuel consum
  88. cvh efi setting base idle
  89. help with intermetent sparking issue
  90. Help with this leak!
  91. oil cooler and oil pressure problem cosworth
  92. Cologne 2.9i V6 engine replacement.
  93. battery strap bolt
  94. BMW help (poss ripped of by garage)
  95. spacer kits
  96. yb bottom end rattle….
  97. Focus tdci Aux belt squeek
  98. st 225 brake fitting please help
  99. Head welding then line boring any recomdations ???
  100. Fiesta mk3
  101. non starting tdci mondeo - who has a box of matches
  102. HELP!! broken PATS chip
  103. engine code
  104. Bike throttle body advice
  105. trigger wheel mfi to efi rs turbo
  106. corsa electric power steering ford sierra
  107. 1.6 zetec in Ka rally project - ECU?
  108. fuel pipe setup with gsxr bodys and st170 mani and rail
  109. megasquirt map for zetec turbo?
  110. megasquirt need a little info
  111. Fitting GAZ Coilovers
  112. fiesta mk6 questions for project
  113. Battery drain
  114. Ka /Puma rear axle width?
  115. focus stuck in zetec
  116. MK1 Focus TDDi leak from somthing?
  117. volvo 5cyl into ford p100
  118. Zetec into Sierra??
  119. 1.4/1.6 cvh engine questions
  120. Fiesta zetec S help oil issue
  121. S2 RS Turbo Master Cylinder
  122. Help help
  123. Cosworth mt75 gearbox
  124. wossner piston ring end gaps..calculation check please
  125. Electrical problem with Ford Focus C-Max 05 plate petrol
  126. Idling problem, please help!
  127. Fiesta starting problems
  128. Escort RS2000 Lambda help
  129. sierra pinto automatic?
  130. Who,s good for biulding cossie diff,s???
  131. mondeo 2.0 tdci auto box fault
  132. Tt top hat
  133. Cosworth 4x4 twin plate clutch
  134. cosworth oil presure problems! help needed
  135. couple of technical issues
  136. wierd temp gauge
  137. Ford Ka - Engine Racing
  138. Engine Builders. Advise wanted
  139. Cosworth 2wd propshaft
  140. Ford focus 99 blowers not working
  141. YB Rear Crank Seal (fly wheel side)
  142. What is this?
  143. YB Cosworth cam belt noise
  144. zetec turbo head gasket and bolts
  145. cosworth fuel pump loom help
  146. Zetec cam belt setup (blacktop head silvertop block)
  147. FRST running issue...
  148. Cossie head re-build /preventative maintenance
  149. Zetec turbo alternator belt?
  150. Fiesta fun
  151. Ford mondeo mk3 tdci not starting properly
  152. Mondeo ST220 Ecu fault codes....
  153. Rev counter
  154. Temp gauge off the scale
  155. help needed by mechanics renault not ford
  156. st 225 brake fitting please help
  157. t3 t34
  158. Mk2 focus estate on 18s
  159. 2wd and 4x4 head valves
  160. cossie head mim thickness
  161. Zetec s
  162. fiesta clutch switch
  163. RS Turbo wire to fuel pump
  164. Pinto head ID marks
  165. Engine Block Cleaning- oil ways etc..
  166. 1300-1.25 wiring loom/ ecu
  167. beestieboy Fiesta over heating,need help
  168. Type 9, 5 Speed Gearbox help :)
  169. Zetec Turbo but WHAT turbo???
  170. MK4 Escort XR3i Cabriolet rear tierod bolts
  171. CVH 1.6 carb Spark plugs
  172. Mk3 zetec conversion help please
  173. Escort s2 and Orion 1600 cvh
  174. Cosworth Brakes wont bleed
  175. who sells 1.5 bar actuator springs? cone shaped type?
  176. wiring for 1.25 zetec hotrod /grasstrack car
  177. tricks for removing cossie bottom pulley
  178. 1300 Cvh
  179. Doing a shopping list for my project looking for some advice please :)
  180. Rs1800 Zetec into mk4 escy van
  181. Mondeo 54 Plate ztech help plz
  182. driveshaft snap ring snapped, half missing
  183. Engine & gearbox fitment trouble
  184. rodeo 2.5 tdi
  185. Turbo choices
  186. Pinto engine
  187. What is this bellhousing ?
  188. Comp Cams
  189. Ford Focus 1.6 Zetec (2002 - Automatic) - EML Issues
  190. S2 RST strange boost problem
  191. zetec 1.25 ecu identification
  192. A4LD Gearbox Oil Filter
  193. How much bhp can erst cv joints handle.
  194. How much bhp can erst cv joints handle.
  195. Wiring diagram for heated front screen
  196. what is t correct amal valve piping? boost problem
  197. hydrolic lifter problems
  198. Cosworth fuel pump fitting to a RS s2
  199. 3 Pin Fault Code Reader Help
  200. Lack of torque steer
  201. Escort Cosworth fuse box
  202. So, about these 6 wires.....
  203. Cosworth will not start
  204. Some advice please.
  205. internal pictures of oil dry sump tank
  206. Fan relay location mk4 fiesta
  207. 2ltr Mk3 fiesta question..
  208. Distributor earthing
  209. Efi to mfi gearbox swap
  210. Hole Measument
  211. Escort cosworth ABS pump not working
  212. EFI pressures please
  213. YB exhaust manifold
  214. Escort cosworth sensor oil pressure banana pod original gauge
  215. Ford Fiesta- Cutting Out
  216. should a boost gauge make a noise!
  217. Focus ,no go! ?
  218. fiesta rst struts same as xr2i
  219. Removing Air Con from MK6 ST
  220. Engine management light.
  221. cosworth exhaust stud question
  222. Flat Battery - Escort Cosworth
  223. Yb crank bearing clearances
  224. wasted spark conversion
  225. yellow relays in engine bay loom x2
  226. Morette Bumper Indicators
  227. Please help with fault code
  228. Question regarding Rattling cat.
  229. ST170. Oily Substance On Clutch Pedal!
  230. Fitting Zetec Engine
  231. what are the difference between the mazda 2.5 and ford 2.5 America duratec
  232. Cossie Engine Loom Resistnace Results
  233. Rear crankshaft oil seal
  234. rusty fuel filler pipe
  235. Zetec pre pats looms + ecu
  236. HELP.......2WD Oil Pump
  237. MSD wasted spark kit
  238. Anyone with a heated front screen...
  239. Oil leak from Rocker cover object
  240. Running in CVH
  241. turbo diesel white smoke
  242. 4x4 outer cv's
  243. sierra 2.0 dohc upgrade advice pls
  244. Wasted spark conversion
  245. MK3 Escort Brake Upgrade
  246. Puma Conversion into Fiesta
  247. XR3i Cabriolet Owners can you shed some ight
  248. Escort mk2 pinto
  249. which bolt for zetec dynamo tightener(?)
  250. wasted spark conversion
