MSD wasted spark kit
Old Sep 15, 2013 | 10:58 AM
cozi500's Avatar
cozi500
Default MSD wasted spark kit
Hi all i know one or two MSD guys are generally on here, i recently purchased a full MSD wasted spark kit, im having a few issues with wiring the driver board into the ecu. After carefully reading the instructions i have wired the first part up ecu side to the ecu respective pins, remembering to snip them and wire to the pin side not the ecu board, side, the issue i have when turning over the ecu to wire up on the solder side, the instructions give you pin numbers, firstly do the remaining wires need to be soldered to the board corresponding to the ecu pin numbers, the reason i ask is because the illustrated picture shows the wires being soldered in a completely differant place to the instruction? can anyone help as all the MSD techs are on holiday for another week. I need to get it sorted before that, please any help is appreciated
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
deathrider666
Sep 28, 2015 06:12 PM
