Comp Cams
Old Oct 8, 2013 | 07:57 PM
Alan G's Avatar
Alan G
Default Comp Cams
Hi all,
Just looking to see if anybody on here has any experience about running a pair of Comp Cams in their 2.0 Blacktop Zetec.
Here is a bit of information on the three different spec. cams that C-F-M offer
Serious Street/Race Cam (1400 to 6000rpm): Duration for inlet & exhaust = 273 degrees each. Valve lift inlet & exhaust=0.381 inch each. Full lift inlet & exhaust=112 degrees each.
Severe Street/Competition Cam (1800 to 7000rpm): Duration for inlet & exh=281°. Valve lift inlet & exhaust=.381". Full lift inlet & exhaust= 112°.
Competition/Pro Race (2200-7400rpm): Duration for inlet & exh= 289deg. Valve lift inlet & exhaust=.381". Full lift inlet & exhaust= 112°.
The COMP Cams Ford Zetec 2.0L camshaft sets are designed to work with the stock valve train components, making for a simple "drop-in" installation.
http://www.c-f-m.com/performancepart...SVT-69p829.htm
What are peoples thoughts on these?
Cheers,
Al
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
