View Full Version : Technical help Q & A
- Whining from front wheel?
- 5bar map sensor
- cossie help
- escos cutting out
- MK5 escort fuel tank wiring
- Saf cos moves from side to side???
- BD10 CAMS
- No heat !!
- How many litres of coolant do I put in cossie.
- Just fitted 500 i/cooler but hose now in the way of airbox.
- Loctite on exhaust/inlet manifold bolts?
- idle control valve
- Esc cos (Small Turbo) idle fault
- car revs by itself!.....any ideas
- Cometic head gasket torque setting?????????
- Catalytic Converter on the way out?
- Removal of Aircondition???
- sunroof
- Ford alarm probs after new w/screen fitted!!!!? Now Sorted!!
- Master Cylinder Cost on 2wd Cosworth
- S1 and S2 engines
- MK6 Diagnostic Connector
- Very hot s2
- Need help with 4x4 Sapphire!
- Ford oil separator modification
- Escort Cosworth Electrical Fault
- Escort WRC suspension.
- FAO Stu or Sean or Brom or Mike R, or anybody who knows!!
- please help, no boost from turbo
- Cossie not starting
- Water Pissin Out!!!
- smoking erst
- 12volt power supply
- Radar Dectector's
- Loom question
- MOT. pass, brakes and arch liners?
- Diff Ratios....Effect on Driving???
- Eibach spring kit ...ERST
- Max wheel and tyre size
- what intercooler
- S1 rev counter and coil Q ???
- fitting focus/mk 5 essy clutch ratchet
- escort turbocharger
- Viewing a saff cossie....
- Drilling an air box????
- T5 Borg Warner gear box
- Timing Disc on Sapph 4x4 Pulley????
- grey injectors for stage 3 conversion
- possible turbo problem
- T34-.63 vrs T4
- Focus rs
- T34 POWER OUTPUT?
- Quick tyre question
- 3 Bar Map Sensor on FRST
- Starter motor
- intercoolers
- 2ltr zetec into mk6 escort
- plug gaps!!
- Cossy rev counter problems
- Eary saphcos 4pots on erst?
- advance and retard on bd10s
- New TCA's question!!
- Mondeo 2.5 V6 tuning
- 330 bhp tuned sapphire advice on head gasket
- s2 heater
- Exhaust, mk5 turbo
- Sierra fuel pump
- not very tech but still need help??
- FRST Being a Bitch, please help!
- Dizzy question
- erst over heating
- CVH head oversized tappets
- Powerstation rolling road
- fuel gauge......
- Cheaper clutch
- T3 cosworth boost question
- ecoz strange engine problem
- what springs for a BD16
- blown head gasket symptoms
- mondeo si v6 miss fire
- Can I run a T34 on a standard saph??
- xr2i turn into rs turbo wiring
- Electrical problem on S2
- need a quick response on this one
- Wide Band Lambda...Experts please???
- METERING HEADS???
- 202 block
- Will this work? 3 bar, 801's and standard chip?
- front end vibration
- Intercooler nightmare
- what does my power graph show
- Loose oil dipstick tube!
- mondeo clutch cable replacement 1.8 td
- rear beam bushings again....
- Large wobbly front...
- Dead ABS
- My rs 2000 god dame handbrake!!!
- Will a T35 from an esc fit a 3dr.
- ERST 90 spec
- Magic Missing Fuel Pump Volt
- Removing RS Turbo pistons from rods...
- 1.6 efi cvh - What options do I have?
- painting chips
- Bailey breather and cam cover
- Matching fuel pump to injectors.
- injector CCs
- cossie ecus
- dump valve question
- koni suspension
- swirl pot advice
- swirl pot advice
- 17"s on a bouncey mk 4??????
- Strange noises!!!!
- oil breather....kidney pot
- RS turbo downpipe
- Starter Buttons?????
- Electronic boost controllers
- Top end tick on a 4x4 Cossie
- what engine oil for a cosworth
- P8 /L8 interchageability
- Heater and indicators
- best fully synthetic oil for a s2
- Quickshift gear mechanism for a 4x4 saph cossie
- s2 rs turbo injectors please help
- S2 RST problems, help?
- rear beam bushings 4x4 saph
- ESCORT RST CAM INFO NEEDED!!!!!!!!!!
- rs turbo oil pressure light.....
- Ohm's law and changing wire lengths.
- Rebuilding cvh
- what is the CORRECT way to fit lifters on a cvh
- Long pedal travel on 2wd Sapphire
- 2wd back to standard
- 4x4 saff cuttin out
- Small valve marks on top of pistons, will i need new pistons
- Bottom End
- 4x4 Cosworth torque distribution ?
- misfire ? 2wd saph
- What to try next?
- s2 fuel problem please help
- 2wd sierra sapphire wastegate
- how hard is it to chip a xr2i
- Mk5 Clutch pedal too high !
- driveshaft
- Running chip with different spec....
- ford ka rs turbo conversion
- Boost limit on S2 RS Turbo
- gearbox and clutch
- VALVE GUIDES?????????????????
- strange problem
- rose-jointed suspension
- Turbo Help
- Fuel Pressure...Anyone know how high it goes???
- Standard 2wd Cossie Cam dimensions
- air fuel meter
- tyre size
- 4X4 SAPHIRE MISFIRE
- High Comp or Low Comp
- dump valve
- Ignition Advance
- Enigine stall after boost
- load banging noise
- Which Ignition Leads For A 500BHP+ Escort??
- Door Dash Light
- 2.5" or 3" bore mongoose on series 2
- Boot soliniod
- coil overs
- Gearbox oil
- front universal joints type 2 and 3 gearboxes (RWD)
- coil over fitting kit
- 4x4 Clocks in a 2WD Cos
- before you start the engine ?
- P8 ecu query...
- Roof Rattle
- Quicky; hesitating T28 Cossy
- Cossie ECU information
- Blitz Oil temp gauge stopped working
- wheres the best place
- idle problem
- Fuel pressure on Cosworth running greys?
- Sooty black plugs on Cossie
- alarm/relay problem
- Possable ECU Fault????
- knackered big end?
- help needed plz
- My 3 door barely runs
- engine idle problem?
- breather box/firebox
- fuel pump???????
- C O on 2wd saph(fao stu)
- 8 injectors
- Cossie 4x4 steering racks
- Rocker cover gasket
- 3 door ....poor running ????????????
- XR2 Turbo (Fiesta Turbo Lump)
- head gasket problem
- Escort mk4, fitting a vacuum gauge
- Boost,Amal Valve,Actuator.....??? Can someone please explain
- Max boost pressure on Ford 'I4' engines ?
- running big turbo esc cos without dumpvalve
- HELP TD MONDEO OVER FUELING
- HOW MUCH BOOST CAN U RUN ON A ZVH LUMP
- what compression should I be looking at (ERST) ?
- Anyone popped their amal valve before!!!!!?????
- high oil pressure on s2rst?
- Hi Lo Boost on Cossie
- turbo noise ?
- Bd 16 cams
- E453CGN
- Erratic idle
- Turbo timer...
- Turbo timer...
- Turbo timer...
- Forge front mount
- Cossy Engine attn. ENGINE BUILDERS
- fezzy gearbox
- bleed valve or amal valve
- FIESTA RS TURBO T3 CONVERSION
- saph cosworth sideskirts
- Big turbo water injection.
- 2wd/4x4 question
- bd 10 s
- 5th injector kit onto S1 ?????
- Bd14 Cams
- Little button in 2wd sapphire?
- Bit stiff when its cold!!!!
- irratic rev counter
- cossie pistons
- is it the cam? help needed!!!!!
- 3 door cos trailing arm bushes?????
- idle speed
- Esc Cos ABS - want to turn it off!!
- Escort Cosworth speedo.
- Trijekt
- Electrics
- fuel computer thingy
- 3 door cossie questions
- injectors
- Help Please - Indicators Won't work.
- head gaskets
- Esc Cos 18" wheels - what tyre size?????
- pacifica blue paint code
- what do u guys recon i should do ?
- which management
- Cossie breathers
- Loosing water (FRST)
- high reving saffy from cold
- Series 1 Rose Joint dust covers ?
- Help Please! A lack of spark!
- Injection
