12volt power supply
Old Jan 18, 2004 | 04:50 PM
Default 12volt power supply
I have a flat batery on my cosworth, AGAIN, i dont use it very often but it needs to stay alarmed as its kept on the stereet. The trouble is its flat and i have delocked the car all round, i can gain entry again but would like a remote12v supply so i can plug a battery in to a secreted socket mayb to power it back up if it happens again. I have seen it on show cars, redline feature cars i think, max power project pinky RS2000 etc, any idea where i might get one from and fitted?
Old Jan 18, 2004 | 07:54 PM
PJay's Avatar
PJay
I could make you something up depending on exactly what you want, Send me a PM detailing exactly what you require
PJay
Old Jan 18, 2004 | 09:27 PM
THE RADMAN's Avatar
THE RADMAN
i used to run a couple of wires from the battery and tuck them up inside the arch liner, insulated obviously,then when needed just pull em out and connect to a spare battery
Old Jan 19, 2004 | 08:44 PM
That worked did it RADMAN? good idea, will be in touch PJAY, what is it that you do as i`m new here, you a mechanic, retail etc? regards.
Old Jan 19, 2004 | 10:17 PM
PJay's Avatar
PJay
Mechanics and Electronics
Old Jan 20, 2004 | 04:18 PM
THE RADMAN's Avatar
THE RADMAN
[quote="MrC"]That worked did it RADMAN? good idea Yeah, just remember to colour code or label the wires so you dont forget which is which!
Old Jan 25, 2004 | 09:31 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
Can just run two wires from the drivers door CL motor down to an access point, connect a battery up to undo that lock and your in
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
