breather box/firebox
Old Dec 24, 2003 | 05:34 AM
3door's Avatar
3door
Default breather box/firebox
just removed the breather box/firebox on my 3 door 2wd cosworth to attatch hose for grp a breather and it was a bit stiff to get out but when i put it back in it seems a lot looser is it meant to be glued in or have a rubber grommet or anything or is it just a coincedence
Old Dec 24, 2003 | 12:55 PM
cossymad's Avatar
cossymad
Same when I was doing my 200 block. I used some araldite/ chemical metal style gasket sealer- this should work fine.
Old Dec 24, 2003 | 01:09 PM
RSrussell's Avatar
RSrussell
do you mean the flametrap mate?
Old Dec 24, 2003 | 07:24 PM
THE RADMAN's Avatar
THE RADMAN
when i fitted my ggr one it was the same,just wants a drop of glue as already said,just make sure you only put it on the adaptor and not in the hole,that way it cant be pushed inside the engine when you push it in
Nov 1, 2015 06:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
kevin36
Sep 2, 2015 06:24 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
