Removing RS Turbo pistons from rods...
How do u go about doing it? No circlips, and i've been told i'll have to go to an engineering firm to get them removed.
Any other way i can do it myself, without damaging them?
Yes you would have to have the pin pressed out with a hydraulic press.
Even with a press it is hard to remove the pin with out damaging the piston
As there is no flat on the side of the piston to take the load
this not a D.I.Y yob
Hope this helps
Steve.
Hope this helps
Steve.
big_Rad
15-09-2017 09:36 AM
Matt Baxter
16-09-2015 08:30 PM
ekjim
17-08-2015 08:57 PM
