ERST 90 spec
Old Jan 8, 2004 | 10:23 PM
rsturbo2's Avatar
rsturbo2
Default ERST 90 spec
Keeps over heating any ideas to what to look at ?
Old Jan 9, 2004 | 09:46 AM
fan working? air locks?
Old Jan 14, 2004 | 01:23 AM
rsturbo2's Avatar
rsturbo2
fan is working
Old Jan 14, 2004 | 09:43 AM
Windle's Avatar
Windle
fooked rad ?
Old Jan 17, 2004 | 04:33 PM
I had the same problem with my old s2 a garage told me my head gasket had gone, but some one told me to try taking the thermostat out, so i did and it was fine ever since.
I'd recomend doing this first all you need is a 13mm socket and it only takes about 5 mins to take off the thermostat housing and put it back on (be carefull though theres a paper gasket between them, but then a new one shouldnt cost much if you tear it)
Old Jan 17, 2004 | 06:42 PM
PJay's Avatar
PJay
I would not competely remove the thermostat as this will make the car a bitch to warm up, by all means check this but i wouldn't run a car without one
PJay
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Mc5506
Oct 5, 2015 09:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
beller
Sep 21, 2015 04:13 AM
