tyre size
Old Dec 31, 2003 | 02:24 PM
Default tyre size
running a standard rear end on a three door what is the size of the largest tyres that will fit under the arches.car does have coilovers thanx
Old Jan 1, 2004 | 09:19 AM
Alvyn's Avatar
Alvyn
I have 225/40 17" rims are 7.5J on the rear of mine and have coil/overs! If that helps @ all!
Old Jan 1, 2004 | 09:27 AM
POPEYE's Avatar
POPEYE
FAIRY CAKE
you should be able to run 8" wheels with 235/40's no problem if it aint lowered
Old Jan 1, 2004 | 09:28 AM
will 245/40 hit the lip of the arch cos i want to fill that annoying gap between the tyre wall and the arch
Old Jan 1, 2004 | 09:59 AM
POPEYE's Avatar
POPEYE
FAIRY CAKE
think it may be a bit big mate,without doing any arch mods
Old Jan 1, 2004 | 02:14 PM
at least with 235 the tyre edge will be 10mm nearer the arch so thanx,would it be possible to just rub the inside of the arch so that i could put 9" rims on the rear with 245 tyres? or am i just hoping for too much
Old Jan 2, 2004 | 09:34 PM
To my knowledge the rear arches are structurally important, on the sapphire any way, not sure if it applies to the 3 door. If you start cutting, folding or grinding them back it could effect the torsional rigidity (I used big words) and knacker the handling.
On the other hand, I could be talking complete crap, if so please ignore the above and enjoy the following tune,
tumm tee tee tumm, tee tee tumm, tee tee tumm, laa, la la laaa la la tumm, tee tee tum.
tankybaby66
Feb 6, 2016 02:24 PM
gcfcos
59
Oct 6, 2015 05:04 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
