Matching fuel pump to injectors.
Old Jan 8, 2004 | 01:43 PM
Default Matching fuel pump to injectors.
Hi guys,
When swapping from standard injectors to uprated ones - green or otherwise, at what point should you swap your fuel pump? Is there some way to work out what pump is best matched to the flow rates of the injectors being used? Sorry if this sounds silly, im not too up on how EFi works. If anybody knows some good reference sites that would also be handy!
Cheers!
Old Jan 8, 2004 | 02:45 PM
Dave Henshall's Avatar
Dave Henshall
on a escos, you need to get either the grpA one or the walbro like for like uprated replacement one as the escos std pump is the same as any other efi escort and just cant supply the fuel when bigger injectors are used. a saph can handle greens on its std pump , but if its never been replaced it will be getting slightly lower pressure than when new, so i would change it aswell better to be safe for the sake of 150 quid.
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
15
Oct 7, 2015 03:43 PM
gambo08
Fiesta RS1800/RS Turbo
Sep 16, 2015 08:10 PM
tib2220
Sep 14, 2015 12:33 PM
