oil breather....kidney pot
just fitted my oil breather....spec r type......
steve scott gave me a fitting that does away with kidney pot and just pushes in...but......there is a smaller pipe that runs from kidney pot into side of plenium...... can this be blanked off????
Thanxs in advance
regards
steve
Thanxs in advance
regards
steve
Just had a look at fitting instructions for my bailey breather they mention removing the hose that goes back to the inlet manifold I also need to remove the large union that screws into the inlet manifold I have a blanking plug 1/8th npt for this Would think you will need to do the same?
