car revs by itself!.....any ideas
Old Jan 23, 2004 | 01:24 PM
Default car revs by itself!.....any ideas
Have a saff 4x4 '90.When its at running temp everythings mint,however starting from cold, car will occasionally rev by itself, it spikes straight to 2k sits there for a second, then drops back to idle.Also when driving car cold it hesitates, as if my discs are warped badly and catching(this has been checked and is not the case).
I have changed some parts, ie leads,d/cp,r/arm,coil.Have also eliminated TPS, all of this makes the car a whole lot better......but only when its warmed up. Any suggestions much appreciated, been driving me nuts for months now
Old Jan 23, 2004 | 01:27 PM
could be the 3 block plugs, on the bulkhead, i had the same prob. took them apart, cleaned them, did the trick
Old Jan 23, 2004 | 01:29 PM
Will try this eve m8, cheers
Old Jan 23, 2004 | 05:06 PM
no joy
Old Jan 23, 2004 | 05:16 PM
could be an air leak somewhere any air pipes on the inlet side
Old Jan 23, 2004 | 05:25 PM
steveRS's Avatar
steveRS
i have same prob!!!!
Old Jan 23, 2004 | 07:01 PM
3door's Avatar
3door
get your co2 checked if ur running lean then car will fluctuate at idle until warm when the idle valve wont be needed as much
Old Jan 23, 2004 | 07:18 PM
All fuel is spot on, was set up recently, convinced its a problem elsewhere, been advised that coolant sensor may be dicky, so gonna try this next, fingers crossed
Old Jan 23, 2004 | 07:19 PM
steveRS's Avatar
steveRS
were the fook is that?
Old Jan 23, 2004 | 07:26 PM
Its on the head, pass side, but is not to be confused with the temp sender for dash.Apparently its further back.Gonna av a prod round 2 moz.Had enuff of the thing for tonite!....will post results
Old Jan 23, 2004 | 07:30 PM
steveRS's Avatar
steveRS
more confused !!
has any one got pics for "the idiots guide to"
lol
Old Jan 23, 2004 | 07:32 PM
Not had a look yet m8, so cant tell where exactly it is
Old Jan 23, 2004 | 07:34 PM
steveRS's Avatar
steveRS
fooking cars !!!!!!!!!!!!
wanted: 1 bicycle-must have front and rear lights
will p/x cossie WHY?
lol
Old Jan 23, 2004 | 07:39 PM
Cossie shaped house extentions..........................wonder if they will catch on, beats a conservatory!!
Old Jan 23, 2004 | 11:31 PM
Stu @ M Developments's Avatar
PassionFords Creator
Old Jan 23, 2004 | 11:58 PM
Steve, it's a blue sensor just to the left of the coolant hose, that comes of the back of the head going to the oil cooler, behind/round about the dipstick.
Bit of a bitch to get to... but defo sounds like your problem.
HTH
Iain
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
cozzy jeff
Aug 14, 2015 05:46 PM
taylora1409
Aug 12, 2015 12:06 PM
stevierob
Aug 11, 2015 09:08 PM
turbobill
Aug 9, 2015 05:21 PM
