head gasket problem
Old Dec 21, 2003 | 03:59 PM
tonypastie's Avatar
tonypastie
Default head gasket problem
Hi I just bought a suzuki jeep sj 1300 with blown engine appartnly the block is cracked hence why i got it mega cheap! so i can go play in the woods after inspection I have found that block has a small crack between cyclinders 2-3 but this engine has linners instead of boared block.
http://img4.photobucket.com/albums/...ie/DSCF0016.jpg
http://img4.photobucket.com/albums/...ie/DSCF0010.JPG
http://img4.photobucket.com/albums/...ie/DSCF0008.JPG
http://img4.photobucket.com/albums/...ie/DSCF0013.JPG
the linners are undamaged but the head gasket has blown where the crack is between the cylinder 2 and 3 fire rings! so this is what I am thinking of replacment engine at £200 which could do the same in 2 weeks or repair the crack with chemical metal (i will open it a tiny bit to fill it) and skim the head and put it all back together with new head gasket what do u reckon?
dombanks
Sep 21, 2015 08:38 PM
Chopshop85
Sep 12, 2015 06:42 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
hopper350
Sep 4, 2015 12:53 AM
