- need a 1.8 engine wire diagram
- cat on 1.8 zetec
- ENGINE PROBS help
- help needed with my saff cosworth.
- off set on wheels
- mk5 rs2000 engine torque settings????
- wheel clearance issues!!!
- ST24
- COSWORTH ESCORT CAMS
- Rattley Zetec 1.8
- Having starting issues with my Escort TD run around - UPDATE
- Scort hunting
- mfi/efi conversion
- new alarm help anyone?
- ap clutch
- Mondeo engine problems
- Zetec Crank Pulleys
- rst idle problem.
- hydrolic Lifters
- S1 intercooler
- best mods for 1.4 mk6 fiesta
- what offset
- zvh
- Turbo's, Superchargers and the dreaded dump valve
- hi hope you can help
- Puma Millenium leather recaros
- power steering
- where can i get an st 24/200 engine ?
- S2 ERST Oil Stem Seals??????
- bit of a problem!!
- Ford escort 1998 rear drums
- Sports Cat Noise
- WHAT LB SPRINGS DO I NEED??????????????
- FUEL PUMP QUESTION (RST AND COSSIE)
- changing shock absorber help please
- 2WD Cossie standard mains cap bolt torques.....in need of :)
- cosworth boost problem
- Help: Ford Fiesta Door Panels
- L6 ecu
- how to undo speedo cable from back of clocks!!
- escos head gasket
- focus starting problem
- Starting problem, possible starter?
- Phase sensor and crank sensor gaps...
- escort coss help
- Cut out :(
- crankshaft noise
- saff cos polly bushes
- Idle problems.
- Hydraulic Handbrake on 4wd and std brake system
- frst chip 165/195?
- 2.0 ecu probs
- suspension help
- ecu chip
- van wont rev over 3000 rpm??
- Banjo bolt for fuel filter - where to get a new one?
- Dump Valve Question
- vernier pully help.. how to
- Poorly fiesta.......
- Fuel pumps
- erst s2 help me keep her cool
- pinto and cosworth yb head
- Sapphire Cosworth Door Mouldings
- NO BRAKES
- Zetec help please
- tighting accelerator peddle???
- Fuel line Noise
- XR2i MAP Sensor???
- Brakes on S2 tubs
- ESCORT GTI
- Failed Emissions on CO level
- Tearing my hair out.....
- Head gasket gone!!!!! Best 1 t replace with????
- UPRATING/STRENGHTENING STRUT TOPS FOR COILOVERS?????
- Rs 1600i Twin anti-roll bars
- does a xr2i gearbox fit 1.8is 16v engine ?
- Front Disc Conversion - Ford Focus
- HELP needed urgently
- lowering escort van
- handbrake
- electrical problem
- Garrett GT3071R
- s1 block popped
- Escort cosworth Relays!!
- Cosworth engine rebuild
- CHARGING PROBLEM ON MY S2.
- escort mark3 cab panel help
- Fiesta Mk3
- Escort accelator peddle
- ABS lights and Brake light
- clutch ratchet on s2 turbo *fixed*
- ESCORT COSSIE WHEELS
- Gearbox query S1 RST any ideas anyone?
- how to tel a 2.0l black top
- Wiring questions
- Another Dilemma
- wheels
- Quick Question
- Clutc Ratchet
- Over heating!
- Car wont start
- s2 boost?
- mk5 rs turbo
- White smoke from my cossie!!
- lambda sensor issues
- 4x4 dip stick
- gearbox loosing oil big time
- low oil pressure
- morette spares??
- rs turbo parts to mk4 van
- my fiesta zetec s engine broke
- why does my fiesta??????
- Boost gauge question
- TPS connector
- s2 speedo and rev counter dont work...help
- 4x4 Cos Misfire
- s2 zetec bottom end????
- White smoke
- brake fluid
- 2wd exhaust manifold removal
- Is my gearbox fooked??
- Attn: Mk1/2 XR2 - ZVH/Zetec owners!
- mk1 escort rst anyone?
- fiesta raid hp induction kit
- Engine swapping compatibility and simplicity on mk2 escorts
- not sure if these will fit
- BHP Potential of 40 DCOE's with 30mm chokes??
- help with xr3i 130 swap 1.8 to 2.0
- gearbox advice needed please
- zetec into mk4 efi
- escort cosworth SMALL TURBO HELP needed!!??
- steering wheel fitting
- S1 rs gearbox will fit a S2 cradle!!
- unichip help
- which turbo
- EFi Inlet manifold
- plug gap
- Does anybody has a picture of grey injectors please ?
- My amal may be dead!!
- exhaust question
- frst into van?
- 1.8i zetec - 105bhp or 130bhp ? *engine picture*
- MARK 2 XR2 88reg
- Brown crap in header tank
- Throttle bodies or webber twin 45's
- Escort Mk7 Central Locking Module Clicking
- where is the indicator light relay on ford escort mrk 5
- cosworth crank regrind
- REMOVING ABS FROM A 1999 MONDEO???
- help teves
- amal valves
- mk5 xr3i keeps cutting out..
- efi 3i to efi turbo
- wheel bolts
- 2wd running trouble
- s2 rst inlet manifold query
- Escort Turbo Diesel Van tuning?
- mk5 escort van lowering
- chip id
- Loose breather flame trap
- location of pollen filter on the new 05-06 shape focusses
- focus tdci sport
- just a quickie, piston prices?
- Help, rear pad and disc change - GALAXY 2.3 HELP PLEASE
- LHD to RHD conversion Escort Cos
- 1993 escort cosworth
- STARTER MOTOR
- cliford alarm
- 1993 escort cosworth big turbo
- what turbo
- Please help Your my last hope lol
- POWER FIGURES
- fse valve
- is a xr3i the same as a turb meter head
- fiesta rs turbo clutch
- how to?
- S1 RST not going into gear at all! Help
- car not starting please help
- brakes????
- s2 engine installation
- intercooler
- question
- lo boost
- Next stage of tuning
- polybushes s2
- High rev missfire!
- engine swap
- S2 RST power problem!!!
- Worth fitting a panel filter?
- Series 2 batt flat and its delocked how to get in
- S2 turbo problem
- Duratech engine, tapping from plastic intake manifold??
- Mondeo V6 autobox whine
- will it fit my 3 door 90 ammp altern
- piston cleaning
- daft question
- P8 ecu
- revs problem
- 3 dr spark problem
- Saph cossie management wiring
- light blues are they?
- water injection priming pump?
- megasquirt on rst or should i go with cossy bits +ecu
- whats a good price?
- escort mk4 van ,conversion
- Saph Cossie Wiper quiry
- brakes
- pectel wiring
- Help needed from Germany!!!!
- rs turbo pistons
- cossie stalling
- power estimate
- mk3 cutting out
- Would this powerchip work on my xr2i 16v
- c20let mahle pistons for a zetec tubo conversion
- Pin names & colours on Escort Cos ECU
- MK6 Handling problems
- fuel pump!!
- Feza Turbo Oil Leak???
- A quick MT75 question...
- 3 door handling
- finally got the gti in but reev problems
- Handbrake Light - Focus 1.6 2004
- pinto turbo technics
- HELP.......Need schematic wiring diagram for fuse box
- a bit of advice please
- HELP!! Can you fit an escort rst lump in a mk3 fiesta???
- strange problems with boost on my s2!!
- HELP - Nebie with dead RST Fezza!!
- 2wd saphy flat spot
- frs - hesitating and stalling
- abs warning light on! how to get it to stay off
- what do i need????
- series2 gearbox replacement
- Big problem stopping my car pass the MOT.
- 2L Throttlebody on 1.8 with EFI manifold
- Bonnet Catch
- rs turbo problem
- Please help, no comp on a cylinder?
- pls help my wiring has gone mad
- still no joy wit my rs boo hoo
- Cutting out OFAC
- Help. Dam cos engine has probs
- breather problem
- Cougar A/c
- Fiesta Fuel Pump Problem :-(
- How can i test my -31 actuators spring,seems weak.
- misfire
- Whats the best thermostat to run in zetec turbo?
- amal valve pipes
