Does anybody has a picture of grey injectors please ?
Rally nut
Hello !
I ordered from ATM a set of 4 grey injectors, but they are not Bosch (I only see the Weber logo on them). Does anybody has pictures of the injecteurs (if possible from all the side of it) ?
I would like to be sure they are REAL greys 403 before I flow test them (it would save me lot of time).
Thanks in advance lads !
Football Cwazy
i have no pics, but there should be a part number on them - 0280150403.
they look like any other injector but need a fitting kit to use them in cossies ( 2 metal o rings )
Rally nut
Yes, on mines, there isn't these numbers, only 2195 is written on the top of 2 and on the 4 injectors, 4 digits written with a pen. ATM told me they were flow tested and matched together by mountune but I have big doubt about that.
Also there is only a small logo on them : a "W" which is the Weber logo.
Had a saff cos which came with "weber greys"and run with a 2 bar map sensor,boost was set at 30psi !!! Was told by a very reputable tuner they were rs200 injectors with a flow rate not much more than standard so i changed to green injectors before the big melt down!!
DixieTheKid
11
06-06-2020 11:20 AM
SMILER258
28-09-2015 09:04 AM
