1.8i zetec - 105bhp or 130bhp ? *engine picture*
I just bought a 92 fiesta 1.8i zetec. And my question is now, how many bhp does it have? Anyway i can see that on the engine somehow.
Just wondering beacause a friend of mine who is a mechanic says it got 130, but on the web it says 105
just got a picture of the engine. (taken by cellphone)
Dont mind my temporary waterhose solution
Check te internal size of the throttle body. If its is 59/60mm then it is the 130 engine. If it is smaller it is the 105. I think you will find only the RS1800s where fitted with the 130 1800 zetec.
Originally Posted by Dexa
hmm... this is what i measured
[/url]
[/url]
XR2i's r 105 & RS1800i's r 130.
SY
hmm... do you have a picture of both the 105 and 130 i can see?
SY
I suspect the MAFs are different, just because they might look physically the same doesn't mean that they are calibrated the same. The Mondeo 1.8l BLOB, SACK and SEAL MAFs are different from the Fiesta 1.8l 2FCD MAF.
all xr2i's are 105 spec.
even if its got 130 throttle body its probably still got the 105 cams and ecu.
take the ecu out from under the dash on passengers side.
if it ends in cd its a 105
if it ends in bc its 130
Originally Posted by reality
Originally Posted by rs2000mk5
inlet manifolds are identical
that clearly shows the differences
JJ
well i think its more a case of ford using different castings for different years, i have broken 15 zetecs and 6 130's and they have all been the same appart from two l reg ones i had.
1 l reg had the smaller ports but it was 1.6, 1 l reg was a fiesta and the casting saying efi was rough and looks terrible quality.
Just checked the ECU, and it ends in CD
So i guess it only has 105bhp! And yes, it aint got disc breaks on the rear
Can anyone help me how to covert it to a 130bhp version then? Cause then i can take a look at the local crapyard later this week for the parts needed.
Originally Posted by Garage19
Yes 2ltr cams and TB from a mondy will work.
only the exhaust cam is the same as 130 spec.
inlet cams are higher lift on 130.
the maf's are the same/
only differences are;
cams
ecu code bc
throttle body
and oil jets under pistons (not needed)
cams
ecu code bc
throttle body
Yeah? What is the lift and duration of the 1800 130PS and 2000 136PS Inlet cams?
About 105 & 130...
Hello Guys, i buy an rs1800 fiesta mk3 `1993 model.. i see this , discussion, about the 105bhp & 130bhp...Im Little Confused,, But My Throttle Body is flat & 60mm Diameter, when i removed the black plastic hose.. ``i dont have the sticker on the black plastic hose... Sooo i removed the ecu & the code is ``2FDC`` Eec - iv gsktcad 2e211 *b2lc329l6vc* 92FB - 12A650 - DC...
``````I don`t see the BC For the 130bhp or CD for the 105bhp @ the end of the code,, & to check the Cams anyone know about them to confirm which i have, 105 or the 130 One`s.... Thanksssss...
mk3ste
17-10-2021 10:09 AM
SMILER258
28-09-2015 09:04 AM
