PDA
View Full Version : Technical help Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 [106] 107 108 109 110 111 112 113 114
  1. EsCos uprated fuel pumps/fuel lines for 550+ bhp?
  2. want to fit cossy 2wd four pot calipers to rst2
  3. spurrious speedo
  4. what leads to fit to a cossie also missing problem
  5. Mondeo Mk1 Speaker Problems
  6. focus key reprogramming!!
  7. What box 450BHP RST
  8. uprated valve springs????
  9. BLITZ BOOST CONTROLLER HELP
  10. big end shells for a cosworth[NOT!!!!!!] DONT GET CONNED
  11. 2 and 4wd cossie throttle bodies - interchangeable ?
  12. Electronics/Computer Experts....Is this possible???
  13. Boost Gauge fitting Kits.... What do you use???
  14. white smoke fom cossie?
  15. Cosworth Head Gasket
  16. Tappets
  17. head info
  18. Waste gate
  19. performance pulley!!!
  20. Heater Matrix
  21. Testing HT leads!!
  22. best pistons for a zetec 16v 1.8 turbo conversion
  23. air/fuel meter
  24. escort rs turbo series 2 problems
  25. cracked head for the 2nd time
  26. Mark 5 FRST FMIC
  27. group a coil on cos
  28. zetec into mk4 questions
  29. Setting mixture on S2 RST
  30. Fitting three port bleed valve to S2 ERST
  31. cossie haust emissions
  32. help
  33. How many of you have had to renew eng loom on your cossie
  34. TPS voltages on 2wd cos
  35. freeze
  36. stage 3 cosworth?
  37. series 1 tow eye cover
  38. 2wd saff eating too much fuel any ideas !
  39. diesel conrods for pinto/cossie
  40. what oil in s2 lsd g'box?
  41. Fuel cut of switch?
  42. Grey Injectors
  43. Intermitent esc cos volt meter???
  44. quick cossy question
  45. Rear wheel drive cozzy differential
  46. engine conversion
  47. dump valve or no dump valve
  48. Electric problem
  49. burning oil
  50. rear wiper not playing
  51. how do you tell if a turbo is knackered?
  52. rads
  53. ECU Nr. 95AB-12A650-EB/ERIC - 1.8 130 PS ????
  54. WRC rods and pistons
  55. S2 Wheel Clunking/knocking
  56. Smoke signs....
  57. group a coils
  58. another idle speed control valve problem (now sorted)
  59. Bonnet on ERST
  60. good strong clutch/plate
  61. HELP!!!!!
  62. puzzle on the zetec...
  63. xr4x4 wants cosworth 24 valve conversion!
  64. Cossie misfire ......
  65. Help needed with turbo id and your general opinions
  66. coil over set up and refurbishing
  67. gearbox rattle
  68. thicker head gasket
  69. Cos YB Workshop Manual
  70. Stainless Steel exhaust flange for Zetec - Where From?
  71. electrics and wiring-help needed!!
  72. Anti Lag ECU Maps
  73. Oil Pressure Sensor's for ford blocks?
  74. Top End Misfire
  75. s2 turbo dropping boost at about 115 mph
  76. Loosing power steering fluid (in 4x4 saphire cosworth)
  77. fusable links
  78. timing chain rs2000
  79. Hesitation / Kangarooing FRST
  80. S2 Main beam Failure - SORTED
  81. could it be turbo probs?
  82. can anyone help?
  83. rs500 advice wanted
  84. BEST PLACE 2 GET HEAD DUN 2 STAGE 3 SPEC??????
  85. GRP A HEADGASKET
  86. Zetec Flywheel
  87. Thinking about carring out a V6 conversion
  88. how the hells this come off
  89. grinding from front near side wheel on S2!!
  90. misfire when comes on boost
  91. m.o.t question
  92. fitting a 130 cam into a 1.6 zetec...what other mods....
  93. Anyone use or had any dealings with one of these???
  94. camber on esc cos
  95. WASTEGATE/ACTUATOR boost pipe
  96. Small Turbo Escos to Large
  97. bleeding ap four pot brakes
  98. Coil packs - benefits?
  99. compression ratio on zetec
  100. How Quick should Boost come in on a Sapph Cosworth???
  101. Only running 5 psi.. help needed please
  102. dizzy cap for saph cossie
  103. Electrical fault (T25)
  104. ESCORT COS T25 boost setting??
  105. cosworth fan problem
  106. [1982's XR3] Fuel Tank Problem...
  107. cosworth looms?
  108. Help with a Bosch part!!! part number 0280142020
  109. Small turbo Escos - what turbo to get?
  110. For tech advise.. read this first!!
  111. series one hesitating on starting
  112. What to look for
  113. OVER HEATING
  114. Cosworth pistons
  115. rear wiper
  116. Escort cosworth fuse box
  117. cortina
  118. zetec turbo breather
  119. escort cosworth T25 whit GGR stage 2 305 bhp conversion
  120. BD14 INLET CAM
  121. escort rs turbo wont go in gear
  122. alarm / remote central locking key fob programming
  123. Head bolts torque settings/angles for escort cosworth
  124. Spark Gaps
  125. RS Turbo Problems-Posting on behalf of a Friend
  126. A couple of quickies!!!
  127. compression escort turbo
  128. RWD escort mk4
  129. Saphy Cossie Firing on 3
  130. Rebuilding turboes..
  131. air injectors
  132. 2nd hand Gear Box!
  133. zetec turbo engine problem
  134. fiesta mk 5 engine conversion
  135. 1.8td to s2 rst
  136. RS1600i fueling problem.
  137. understeer or just my imagination??
  138. EXHAUST WRAP
  139. 200 Block linering - How much and where?
  140. Frst wont start
  141. off set on 3dr
  142. Wiring fault on 3DR
  143. injectors
  144. Pace Intercooler - Help!
  145. respray questions
  146. esc cos head gasket set????(now with pics)
  147. DIF!
  148. Cosworth Oil Breather Identification/Fitment
  149. RST GTR???
  150. Fan belt replacement question
  151. Zetec Cooling System??
  152. big bhp cossie tune
  153. 3dr recaro seats
  154. RS turbo metering head problems
  155. rs focus ecu diagram
  156. Temp Sensor
  157. over fualing rs 2000
  158. RST big end bearing replacement
  159. seized engine
  160. mk4 efi wiring 89-90
  161. mk4 xr3i 89-90 efi
  162. escort cosworth fuel pump
  163. 2.0 zetec head tuning
  164. super chips
  165. Why would a 2000 mile old exh housing start cracking ?
  166. carbs
  167. clock out
  168. xr4x4 wanting cossy transplant!
  169. SPI head and inlet on RST
  170. I need HEAT
  171. cozzy brakes
  172. s1 /s2 /festa rst flywheel size
  173. Alternator light illuminated
  174. help fueling
  175. combustion chamber cc
  176. cossie clutch cable
  177. pinto head on cossie block
  178. Boost drop S2 ....
  179. seat foam
  180. Cosworth Hydraulic Lifter Cleaning?
  181. how much boost ?
  182. 2 and 4wd cossie ISCV, same or different ?
  183. differences between s1 and s2 running gear... not engine
  184. lsd in a diesel box
  185. Missing on full throttle
  186. strange EFI cold start prob
  187. REGARDING BOOST
  188. S1 trouble
  189. zetec turbo piston/ring problem help & advice needed
  190. misfire and dodgy relays
  191. S2 RST Problem
  192. Erst problems
  193. Workng out the compression ratio on an RS
  194. Compression problems,
  195. focus acceleration vibration MTX75 box
  196. zetec head bolts.
  197. breaking rota arm
  198. ANYONE KNOW HOW TO MAKE AND FIT AN [b]EXHAUST FLAMER[/b]
  199. cooling fans on my saff
  200. for Ford specialists
  201. xr2carb probS, HELP!!!
  202. turboing a rs2000 any one done it
  203. cosworth running problem
  204. zetec head question
  205. cleaning xr2 carb!!!
  206. What is the best gearbox??????????????????
  207. Stuck in another town - HELP
  208. Why always Zetec Turbo conversion and not DOHC
  209. WHY DOSE A COSSIE ENGINE
  210. Overboosting Fiesta RS Turbo!!
  211. CUTTING OUT IN THE RAIN?
  212. Interior and engine fan wont run?
  213. Intercooler spray operation
  214. S1 Turbo box + late mondeo engine
  215. car over fueling bad 2wd saph help
  216. Stroking a YB motor?
  217. why does one cam have an oil groove in it?
  218. van wiring
  219. Escort series 2
  220. Priming up the engine with oil...
  221. 2wd engine rebuild questions
  222. Help Upper bushes of the gear change mount
  223. undersealing
  224. Alternator on sierra cos
  225. piston decking
  226. piston protrusion 2wd cossie
  227. what is the minimum thickness of a 2wd cossie head
  228. Quick question just need a yes or no
  229. erst not starting
  230. rs turbo engine poping underload
  231. Saph 2wd Cossie Gearbox Problem
  232. 2wd cossie missfire
  233. Head gasket
  234. saph crank pully removal
  235. blitz power meter i-D D 1 spec
  236. zetec head bolts
  237. t34 on cossie
  238. Saff cos popping and farting
  239. ANTI LAG
  240. 2wd cos sump gasket, how easy?
  241. GT seires Exhuast housing
  242. Changing exhaust housing over ?
  243. ashly system, hard to fit!?!!?!!
  244. High Pressure Oil pump
  245. Electric Windows :mad:
  246. xr4i janspeed turbo ildling problem
  247. Identifying Turbos
  248. Turbo Technics inplant : Scorpio to XR4x4 ?
  249. 2.0 Zetec in to a mk4 fez, whats involved....
  250. zetec turbo
