air/fuel meter
Old Nov 10, 2004 | 06:49 PM
cit-tech's Avatar
cit-tech
Default air/fuel meter
has anyone used a lumenition afr meter on a cosworth with standard sensor ,which is not hooked up to the ecu ,i have used it on cars which have got lambda in the ecu ,works fine
Old Nov 11, 2004 | 06:34 AM
foreigneRS's Avatar
foreigneRS
Testing the future
yes it would also work on a cossie. there is no difference in lambda sensors.
however, being a narrow band sensor, it's only use is for the ecu to maintain a lamda = 1 running condition under low load conditions.
a narrow band afr sensor / meter is no use whatsoever for tuning, particularly on a turbo engine where richer mixtres are needed on boost. these just cannot tell you accurately what the mixture is.
gingeRS
17
Oct 2, 2015 09:42 AM
A.t.p
Sep 29, 2015 05:04 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
kevin36
Sep 9, 2015 11:12 AM
kevin36
Sep 8, 2015 12:23 PM
