zetec turbo piston/ring problem help & advice needed
Old Oct 17, 2004 | 08:32 PM
jaypen's Avatar
jaypen
Default zetec turbo piston/ring problem help & advice needed
hello all
got a really annoning problem with a full zetec 16v turbo turbo conversion i've done on my FRST its doing my head in
short block has been rebuilt using standard pistons with new matched rings all new shells,new pumps seals,oil sprayjets added,spotlessly cleaned, have had car on rollers recently (run in 1800 miles did miss a beat),only to be told it has low compression & cylinder "leakage) only making 100 bhp at wheels ,advised to take head off see if there is anything wrong,after head was taken off all bores are scored (groves on wall of bores),
all main components ie block, pistons,crank etc checked by a reputable local engine shop before re-build,pistons i used where standard,measured with micromiter to match up for rings.
what i need to find out is the possible cause of this & if anyone has experienced problems themselves & can offer me some advice as to a way forward
thank again for looking
cheeRS
Old Oct 17, 2004 | 08:49 PM
tonypastie's Avatar
tonypastie
come guys i know james he spent lots of money and got no where yet ?
Old Oct 18, 2004 | 07:40 AM
JesseT's Avatar
JesseT
So what caused the scores? Did the rings snap in running-in period?
Old Jun 18, 2010 | 08:05 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
had the engine been mapped?
sounds like it's been running too lean if you ask me.
overheated pistons and rings have been grabbed and casued damage.
Billy_RS
16
Oct 11, 2025 09:41 PM
Churtz
15
Aug 13, 2015 06:40 PM
turbobill
Aug 9, 2015 05:21 PM
Cameron
14
Aug 9, 2015 06:28 AM
turbobill
Aug 1, 2015 08:55 PM
