Setting mixture on S2 RST
Old Nov 9, 2004 | 01:52 PM
davva2004's Avatar
davva2004
Default Setting mixture on S2 RST
My RST is running too rich and overfuelling on boost, so I want to set the base mixture... as I understand it, I have to unplug the wiring from the metering head, run the car at 3000rpm for 30 seconds, then adjust the mixture screw and check whether it's lean or rich by depressing the paddle by 1mm and seeing if the revs rise or fall.... and if I cant get it right within 30 seconds, repeat the 3000rpm thing. Is this right? If the revs rise when pressing the paddle should I turn the mixture screw clockwise or anticlockwise?
And will this actually have any effect on the fueling levels on boost?
I know this isn't gonna be a spot on method of getting it exactly right, but I simply can't afford to get it set up on a rolling road as yet and as I drive the car every single day to work and back I want to get it as close as I possibly can.
Does anyone have a better method that can be done with basic tools, as in no CO gauge or gas analyzers?
Cheers all
Dave
Old Nov 14, 2004 | 04:07 PM
radiant red's Avatar
radiant red
Not the kind of thing you want to be guessing as it may cause your fuelling to be lean if ya get it wrong. Take it to somebody who knows the KE Jetronic system and obviously has a gas analyser. They will be able to set your mixture but it may not solve your problem. When i bought my S2 it was seriously overfueling, i tracked it down the a air flow meter position.
Chas
Oct 5, 2015 07:13 PM
`spotty
Sep 25, 2015 11:41 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
Chopshop85
Sep 18, 2015 06:13 AM
Billy_RS
Sep 13, 2015 04:17 PM
