View Full Version : Technical help Q & A
- 6000 CD Radio issue
- Clifford g5
- Rear Bumper Rivets? Really? Ford Fusion 2, 2004.
- Focus 1.8 TDCI starting problem £1000+ out of pocket :(
- mapping megasquirt
- Cleaning parts
- Am i getting this right? Fiesta/Fusion aftermarket audio.
- Zetec 16v engine not firing pleeease help!!!
- 2000 plate focus cambelt change,probs
- Strange electric issue involving dials and radio
- rs turbo ofab conversion still wont run!!!!!
- 1.8 TDCi Focus - strange noise under acceleration
- Help fitting buckets seats to escort cosworth
- Piston help wanted
- Ford Fiesta Courier Heater Control Panel
- p8 ecu chip for antilag help etc
- Help/Advice
- Engine leak. But from where
- Help wanted
- MK3 escort ing problem?
- Ford Courier van 1.8 diesel heater full on.
- Ford Courier van 1.8 diesel odd noise.
- can i convert my rs2000 4x4 gearbox? (st170 6spd)
- P1518 Checking IMRC on ST170
- Ford escort 1.8 - turbo diesel conversion
- Zetec CPS
- 16v orion zetec loosing power intermitantly
- glow plug problem ford focus
- t.p.s setting
- 2007 Mk3 Electrohydraulic Power Steering Problem
- tyre change p100
- 87 escort rs running poor, popping no boost
- zvh building help help
- Can't open boot using dash button or keyfob! (Fiesta 1.4LX)
- Radiator
- Fan belt diagram
- Focus gearbox problem?
- ford connect
- What if??
- fuel tank breather valve sierra cosworth
- racing puma eratic idle and running rough. HELP!
- galaxy heater problem
- fitting a turbo
- ford focus mk1 collections edition tuning
- Help me ID these Classic Ford parts
- Flashing filiment light
- brake clearance query? rs2000 wheels
- ST170 Solida Flywheel conversion, which one?
- Brake Line Help Needed
- Breather bailey
- type 9 synchro hub spring for 5th?
- Mk4/mk3
- Endura 1.3 Coil Pack Replacement
- Ford KA 1998 - PowerSteering
- MT75 g/box
- HELP!! Mk6 Fiesta 1.4 zetec se petrol head removal
- Help before i set it on fire :(
- Mondeo power steering problem
- Ford Focus 04 TDCI Engine Cooling Problems Help!
- Gear change problems
- S1 EFI ofab conversion wont start!!!!!!!
- Blufin Super chip.
- What Clutch
- Zvh mapping questions
- How can you tell if your car has been chipped or remapped?
- 2.0 blacktop zetec flywheel clutch bolt PCD
- St 170 clutch problem
- how to identify
- fiesta/escort front hubs
- creaking/ scratching noise from front wheel
- Fuel pressure
- Radio code
- Fiesta RS1800 Electrical Problem Help
- st 170 qestions
- mk7 fiesta track car ecu wiring help please
- Chassis "Spit"/Jig
- Ford Focus TDCi 2005 turbine gone - help
- Connect towing question
- Help Please! My van thinks its a Kangaroo...
- aircon problem..
- do me a favor... anyone know.....
- escort van laden valve siezed
- Ford Focus ST170 Isofix solution.
- Shell Preperation sandblasting or soda blasting?
- Van wont start T280 mwb 02plate 2litre fwd
- 2002 focus idle problem - warm startup
- 2.0 tdci mondeo 03 aux tensioner
- The Old RS1600i Tuning Sticky From RSOC
- Mondeo engine keeps cutting out...
- Cvh efi 1.6 heads
- Mk3 escort zetec conversion
- slight "click" when selecting gear
- 2003 diesel mondeo glow light
- Cmax 1.8 starting
- St170 loss of power ???
- mk4 steering rack and pedal box
- 1997 Ford maverick won't start
- Power steering pump on a mk6 escort van
- MK1 Focus Rear Caliper Disassembly
- cruise control not working on 2004 mondeo
- 53 ford focus has loss of power!
- escos fuel pump gone realy loud??
- Fuel Cell
- zetec oil pump
- very quick one!!
- Focus ST170 Headlight Washer stay up.
- St170 engine cutting out
- zetec silvertop engone build
- st170 xenon headlamp conversion
- Problem with wipers, Focus ST170
- Please Help, Enginge Managment Light has come on. DTC 9202
- what gearbox will fit focus
- Pinto conversion
- 2003 focus knocking noise and enigne moving problem please help
- Fiesta MK6.5 door moulding removal
- CVH head woes!
- Mk1 focus central locking problem???
- RS Turbo EFI Rev Counter Problem...
- Fitting DAB radio to MK6 Fiesta (facelift)
- Mk2 granada; phantom driver, starts by itself - help!
- Focus 1.8 tddi ECU Pinouts
- engine running Cosworth sierra 4wd ?
- cosworth crankshaft sensor doesnt fit
- escos missfire on idle when hot and wont boost when hot hot ??
- mk4 escort shift problem
- Rear brake compensator escort turbo
- FAO ST150 owners
- 7,5 " FFD front differential (GPA)
- Mk2 focus rs running problem
- 2003 Ford Fiesta LX 1.25 - A sour lemon
- injector adapters to convert sidefeed hole to take top feeds
- Cosworth wasted spark ignition any good??
- 2006 fiesta knock on rear ?
- help please zetec conversion no spark
- Any Ideas ?
- is there an difference in the 1.25 Zetec Heads?
- Hi is there much between t34 roller bearing turbo and stage 1 turbo technics
- eescort 1.8 noisy cold start
- 2.1 zvh turbo choice help
- Car speakers just buzzing.
- ka steering rack
- Where's the Engine Code on a 02 1.25 fiesta please?
- Focus 2012 S MachII & Auto-window windup
- Escort Mk 3 Sunroof problem
- Can you reuse Fiesta 1.25 Head Bolts
- Engine type
- sierra 3dr rollover jig build advice please
- Code readers??
- Wanted cossie als modded throttle body
- 2005 Focus LX Estate, 1.6 Petrol. Temp. gauge not working.
- 8v DOHC AND 8V SOHC ENGINE MOUNTS
- No go Diesel ?
- lambda sensor
- sierra door removal and oil for newly built engine?
- fse powerboost valve on zetec turbo good or bad
- Sierra Cosworth Cam Caps
- Megajolt or other for rs1600i
- 58 Focus 45k Turbo Boost Issue
- Ford escort mk3 front wings removal.
- Orion Mk1 Zetec conversion oil pump
- Focus TDCi clutch/dmf?
- sierra p100 td starting problems
- Cossie management no spark
- uprated brakes on xr4x4 2.9i - advice needed
- Cosworth vacuum pressure.
- 2009 Focus 1.8tdci cutting out - help!
- cosworth relay keeps click and wont run!
- mk4 fiesta in limp mode?
- Trip computer, fit or not to fit
- Forf sierra 2.0I sohc
- Braking improvements
- mk 3 fiesta convertion help
- mk6 fiesta abs wiring diagram????
- lads what info have you guys got about the ford 2.0i I4 twincam 8v???
- Mk5 Fiesta boot stuck shut
- Clunky noise from engine on starting and stopping. Ideas???
- Focus st boost problem
- Zetec Turbo or ZVH + Which iB5
- IB5 gearbox help.
- transit connect 4 stud conversion help
- What wire do i need ??
- 4WD Gearbox...
- springs or strut tops knocking/noisey street ka
- Fiesta Zetec S TDCI
- Mk2 Escort Panel Help
- gearbox please help
- starter motors
- Temp sender causing juddering?????
- Kuga remote keyfob intermittent fault!
- Start Up
- Loud Clicking
- `2006 Fiesta 1.4 TDCI
- focus idleing/cutting out issue
- zetec 12 pin plug wiring help please
- 2.1 zvh cabby engine upgrades/is it worth it
- T3 5 bolt exhaust housing
- street KA luxury inside floor soaking (seriously)
- fiat coupè brembo callipers on a ford
- mk3 fiesta rs 2000 conversion
- Air con will not turn off Mondeo mk3
- Ford focus ST MK 2 2006.
- turbo y b
- "Deep" mondeo ecu remap
- cooling system on my mk3 fezz rs 2000
- Ford Escort 1.8 Turbo Diesel Struggling at Start UP
- 4x4 center push clutch slave cylinder???
- zetec coil plug wires- blak, blak and red??? can blacks go wrong way round?
- Ford Ka wiring, a lot of stuff not working
- Cosworth YB cam pulley timing position
- escort leaking sunroof ?????
- How to change fuel pump on 2004 focus st170
- Focus st clutch pedal?
- Boost problem
- 2006 Focus 1.8 TDCI Cutting out after 10 seconds????
- V6 24v boa, running without p/s chain guides
- Escort Xr3i alarm operation
- st170 cams in black top?
- water temperature sensor cosworth
- Whats next for the rs
- Emerald ECU maps for a YB Cosworth
- Fitting A Escort RST centre console & digi roof clock into a 1.4 L Escort
- Ford escort mk3 1.6 and xr3 difference?
- FWD zetec flywheel options
- Focus TDCi pig to start
- 1.6 tdci engine fan
- Ford Capri, Sierra independent suspension conversion
- heater resistor
- Red and green wire plug
- Can I put a FYDA engine in my 2001 focus which has FYDB engine code?
- Cuts out when hot
- missing belt but what is the belt for HELPP!!!
- Focus air con woes ...
- oil in exhaust
- t34 rear housing with t4 front wheel .can work ?
- Mk4 XR3i EFI fuelling problem?
- escort van non turbo to diesel turbo
- What amp alternator for rs turbo
- Mk4 Escort Gurus
- Focus rs pistons
- Gearbox, diff & transfer box recommendations HERE >
- Ford Fiesta Zetec (2000) 1.25 Indicators and Heater Blower Stopper working.
- Escort mk2 Parts
- mk5 fiesta big brake setup
- Header tank smelt of exhaust fumes....
- Ecos Intercooler connection
- sierra fuel sender help
- 4x4 head on a 205 block
- 1992 ecos
