t34 rear housing with t4 front wheel .can work ?
hello .. a turbo t34 with with 0.48 rear housing .can work with much bigger compresor wheel with front housing a/r 60 .t4 for example wheel ..can work nice without lag .say your opinion
hi turbosystems i know you are exert on turbos in uk .t34 is capable for safe 1.7 bar with 360 thross and for 385 hp ..if we want to go for 430 hp a hybrid turbo with front bigger wheel like t38 or t4 ?
Mark and t.s. what could be done to a c.r t38 to make it produce better kg sq without increasing boost? Or is it just better to sell and find a gtx or the like? Just want better power without the huge boost pressures cheers.
Sorry for the hijack
Dont like them, Depends on budget I woulf go with a diff manifold and twinscroll turbo.
Mark
Super Moderator
alot will also depend on your engine specification and your budget if you want it fast and cheap just use the Ł860 T36 (these are brand new and have a billet compressor wheel) and std cosworth manifold
You could on the other hand spend 3 k on an manifold + turbo charger
Super Moderator
the t36 has a turbo technics billet compressor wheel, a turbo technics turbine housing and a turbo technics compressor housing and a special garret turbine shaft and wheel and their own ceramic angular bearings
unlike most turbo builders turbo technics actually design and manufacture their own turbos and turbo parts
one could argue that an rs500 T04e is just a hybrid t3
This is the thing, this is on our zt engine t38 we are having to run 1.8bar to get the power we want, around 380/370 we know its a reliable turbo hence using it, but we would like same ish power with less pressure? So is it trade in time? And is a t36 going to achieve what we want,
Cheers fellas
Cheers fellas
track.focus'd
12-08-2015 05:53 PM
Red_bull
09-08-2015 08:34 AM
Graceland
31-07-2015 10:34 AM
