PDA
View Full Version : Technical help Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114
  1. bike carbs on fly by wire throttle
  2. YB cam cap studs
  3. PLEASE HELP! serious braking problems
  4. Problems with speedo and door warning light...
  5. How do you adjust scorpio idle?
  6. 1.8 zvh conversion n/a
  7. berlingo
  8. megajolt management on a zetec
  9. boot spoiler caps 3 door
  10. power plot
  11. dohc 8v forged conrods
  12. Help Needed!!! Snapped speed sensor
  13. rear brakes on a xr3i 1986 cabriolet mk4
  14. Ford Focus - Rear / Side / Dash lights not working
  15. Aftermarket ignition...
  16. central locking!
  17. please help me lads!!!!!!AHHHHHH.........
  18. Gaskets
  19. tail gate opens by itself
  20. ST170 Aftermarket Cams+VVT worth the risk?
  21. Focus rough running after fuel filter change
  22. Upgrading Focus 1.8 Cams
  23. Zetec Engine Wiring
  24. What does these relays do ?
  25. sierra tacho to zetec loom
  26. cosworth rear wishbone
  27. ARP Con Rod Bolts
  28. time clock swap
  29. Help witc bc gearbox
  30. Focus ST gauges in mk1 Focus?
  31. Canister purge valve???
  32. sierra sapphire 1.8 cvh cutting out
  33. Ka Charging problem
  34. what could this be?
  35. cvh efi frst vac and icv piping help!!!
  36. advice needed s1 swirl pot and turbo water feeds
  37. new owner questions.???
  38. mk2 mondeo 2.0 fuel consumption
  39. powder coating coilovers
  40. Engine change - 1.8 to 2.0 Zetec
  41. (2000) Ford FX 3000 CD Player
  42. Petrol tank
  43. Oil breathing problem on Zetec Turbo
  44. Gaz gold coilovers on rear of sierra.
  45. ka central locking ?? remote key work or not?
  46. Cossie Battery Voltage Woes
  47. Blue Alternator Wire...
  48. Mk2 Mondeo 1.8 Fuel Consumption
  49. Focus St3 sensor problem
  50. Zetec throttle bodies
  51. blacktop rocker cover problem
  52. escort gti on tb's
  53. xr3i efi to rs turbo
  54. cvh efi
  55. Need My T5 rebuilt ASAP
  56. mk2 escort brakes
  57. escort cosworth propshaft
  58. One for the electrical/electronic gurus
  59. 1994 mondeo 1.8 mistral
  60. bodywork conundrums ...
  61. Warped block??
  62. Bailey oil separator
  63. oil pressure
  64. Zetec Trigger Offset...?
  65. smokeyyy
  66. Wont start after rebuild
  67. Front mount alternator
  68. overheating focus
  69. Dash Light Bulbs RS Turbo S2 1989
  70. RS Turbo Remote Central Locking
  71. Help! From IB5 to MTX75.
  72. anyone able to help
  73. Mk3 xr2i 16v zetec fuel problem???
  74. CV Joint Sealant - Sierra
  75. 136k Zetec donor engine
  76. 205 gti, 1.9 1.6 fit the same??
  77. citreon dispatch 2.0 hdi 16 v
  78. Efi erst s2 not starting
  79. Focus st3 shudder at peak boost.
  80. ZVH running mfi. is it enough?
  81. How to improve poor road behaviour Mondeo 2010
  82. help needed
  83. Parking sensors problem...
  84. Mk1 Focus RS engine cutting out
  85. cosworth fans current pull?
  86. Aftermarket ECU for ST170
  87. mondeo tdci 2004 cutting out
  88. door locking
  89. Ford Focus MK1 rear suspension knocking
  90. Clutch
  91. escort gti engine bearings
  92. focus mk1 double din dvd
  93. i need help Maf sensor and injector mondeo into rs1800
  94. Focus ST 225 xenon headlamp issue
  95. V6 XR4i and 4x4 sierra engine mounts the same?
  96. ZT compression ratio
  97. I'm getting a dump valve sound with no dump valve fitted...?
  98. help identifiy my turbo
  99. Orion possessed by shaking stevens evil twin
  100. RS Turbo Starter Motor
  101. 2.0 zetec throttle issue???
  102. Non runner XR3i
  103. EsCos Interior Wiring diagrams needed please!
  104. Ford Escort High Revs at Gear Change
  105. 2.1 zetec turbo, 250hp target, which injectors?
  106. mk4 van rear suspension
  107. Using resistor pack and low impedance injectors
  108. which injector mondeo tdci 130?
  109. mondeo mk2 morette problem
  110. Thermostat gasket
  111. ford granada cosworth indicator problem
  112. ford mondeo 2004 tdci duratoq
  113. high level brake light replacement on ford fusion
  114. PF09 Throttle position sensor - how to set?
  115. mondeo tdci rattle on idle
  116. mk4 van brake lines.....
  117. ford p100 fuelling issues
  118. Water leak from exhaust stud
  119. diesel rad
  120. Focus 2008 1.8 Petrol
  121. Focus ST225 Cosworth Transplant
  122. Do uprated cams need to be remapped to the ECU?
  123. 2009 Focus ST Climate
  124. slow cranking starter after rebuild??
  125. megasquirt features help
  126. Temp Sensor Wiring
  127. Turbo removal
  128. galaxy electrics
  129. need help
  130. Helppppppp
  131. ford mondeo st220 aircon
  132. Maff sensor
  133. throttle cable
  134. Ford Focus ST170 + T (turbo)???
  135. 1 lambda, 2 signals
  136. will a RHD sierra window wiper motor fit a lhd car?
  137. 1.8 zetec sump baffle plate???
  138. 2.0 zetec conversion/rs1800 ecu
  139. clicking amal valve cosworth 2wd
  140. Escort Van 1.8d 2000 Endura De
  141. wiring issues rs turbo
  142. Advice or guide needed for zvh build
  143. Replacing gearbox on a 1.4 CVH Escort?
  144. (engine) wiring manual for 1992 granada 2.0 dohc ?
  145. Engine cuts out + fault on dash ?
  146. autogauge tachometer(rev counter)??
  147. fuel help
  148. what are these help!!!!!!!
  149. glow plug warning light mondeo
  150. who has a ford ka haynes manual??????
  151. Urgent Rs turbo engine mount question
  152. focus mk1 '99' problem with sidelight when open car
  153. headlights to come on when unlocking car
  154. Temp Gauge
  155. Mark 1 focus boot open warning
  156. step by step strip down (headgasket)
  157. step by step strip down (headgasket job)
  158. T25 zetec turbo vac hose?
  159. Escort turbo clutch fork wanted
  160. 3dr cossie brake master problem
  161. EVO 8 rear brakes
  162. Alternator on 2 ltr pinto
  163. Turbocharged cars and LPG
  164. 2.0 or 2.1 forged zetec engine?
  165. Ford Focus Cambelt Tensioner issues
  166. escort cossie - tuning guide/help needed
  167. escort gti running problem help!!!
  168. 2001 focus 2.0 estate, lack of power.
  169. Uprated shocks and springs
  170. standard cosworth exhaust
  171. Irregular Boost Levels
  172. escort van door lock 1998
  173. ford focus estate 2007 heater etc
  174. help identifying the engine and ecu
  175. Escort heater blower
  176. elec windows stopped workin
  177. cosworth 2 wd breather
  178. Torque settings
  179. YB info?
  180. Ecu plug
  181. DSci cable.
  182. Does anyone knows the thread size of the boost compensator nut on a lucas fuel pump o
  183. escort cosworth built from many bits....
  184. Zetec air resonating
  185. mk2 rs lsd
  186. Zetec ecu ?
  187. focus rs boost drop at 4500 revs
  188. Help with this little matter peops.....
  189. 2 litre zetec rattling
  190. rst recaros into sierra
  191. transit wont start??? but will start on easy start??
  192. Mk4 escort van
  193. focus engine cooling fan multiplug burnt out.
  194. coworth 1986 wont rev out when hot
  195. T5 Gearbox Electronic Speedo
  196. info needed for single speed fan mod on escort cossie
  197. sierra not getting spark
  198. mk1 focus rs wheels on an escort mk6, possible?
  199. please help!!(charging system)
  200. ford fester engine swap
  201. L8 ECU wiring to got RPM with Innovate LM2
  202. mk6 fiesta flame clutch bleed issues
  203. frst breather fitting
  204. IB5 Escort gearbox diff shimming
  205. HELP!! s2 RS TURBO MISFIRING
  206. fiesta rs turbo fueling problem
  207. 4x4 saff
  208. Mk 1 Focus RS wheel fitment onto a sapphire cosworth
  209. Mk2 Mondeo Brake upgrade to Escos callipers
  210. Cosworth turbo oil return rubber hose
  211. Manifold
  212. 3dr sierra floorpan
  213. fiesta wont start
  214. inlet flange diagram
  215. Cable problem, Escort Zetec engine
  216. C20XE pistons onto mondeo rods
  217. HOW TO FIT A: MK3 Mondeo 2.0 TDCI 130 Tuning box
  218. escort rs turbo series 2 90 spec problems
  219. mk4 escort zetec wiring help
  220. cosworth engine loom
  221. cambelt for Blacktop head on silvertop block?
  222. 'missing'at around 3k revs
  223. electrical fault??
  224. Series 1 adjustable tie bars on S2
  225. Measurement req'd
  226. How to turn up the fuel and boost on the Ford Escort Mk6 1.8 Turbo diesel Endura-De e
  227. oil return on gt35
  228. Lowering a ST170
  229. efi problum? help please?
  230. battery warning light coming on
  231. RWD C20LET Gartrac Escort
  232. focus fuel pump
  233. thumping noise on 2wd cosworth
  234. urgent help please !!!
  235. Is it possible to replace a 1.3 endura e engine with a 1.25 zetec
  236. s2 sr turbo mfi fuelling prob please help!
  237. st170 manifold on silvertop zetec
  238. door glass removal
  239. re circ valve with GT30?
  240. Focus Zetec SE long crank + popping
  241. Fiesta won't start - Please Help!!
  242. Urgent help
  243. fiesta coilovers... which ones?
  244. one for the MOT testers, testing a track car?
  245. mk4 xr3i cabriolet starting issues HELP!!
  246. Urgent help required please!!
  247. Small turbo escort phase sensor
  248. sierra cosworth pedal box re-assembly ... im stuck!
  249. H Reg 4x4 sapp cos electric window problem whilst 2 partly open, HELP
  250. XR3i Turbo Conversion
