Series 1 adjustable tie bars on S2
Anyone know if s1 adustable tie bars will fit on an S2?
Spanner monkey
If you want just the bars, you'll need to get custom brackets made up, but if you want the whole front roll bar, tie rod assembly, you'll need to add a couple of nuts to the front lower box section as some dont line up, then you'll need a mk3 / 5 gearbox casing as theseries 2 gearbox cradle now won't fit!
muz
30-09-2015 08:29 AM
SMILER258
28-09-2015 09:04 AM
