ZVH running mfi. is it enough?
ok so got my 2.1 zvh up and running took it for a test drive and it is perfect
actually idles better and runs better than cvh bottom end and its got tons of oil pressure compared to cvh
it is running a stage 2 hybrid turbo
the question i need answering is that is the mfi going to give it enough fuel on boost? i am not after silly bhp numbers i just want it to be reliable
i have looked into 5th injectors and wide lamda sensor kits but i really am on a budget and as the engine is running so sweet i do not really want to start tinkering too much if possible
it has c20xe pistons and do not want to melt them as it took a lot of machining to get then to fit.
Anyone running a zvh on mfi? if so how long and had any troubles?
Thanks
Thanks
TPM961
Jan 15, 2018 10:50 AM
Eigdoog
Sep 13, 2015 05:46 AM
