Temp Sensor Wiring
Old Feb 6, 2011 | 06:52 PM
Churtz's Avatar
Churtz
Default Temp Sensor Wiring
hi all.
a quick question on the temp sensor for the gauge on a mk4 fiesta. it is a single pin connection.
i have fitted a 2.0 blacktop in there and the only place i can now mount the sensor is too far away for the wiring to reach. Can i simply extend the wiring or is there something special in there?
dont really know how this type of sensor works as its just a bolt thread for the wiring plug to clip on.
Any help appreciated.
Thanks,
Matt
Old Feb 6, 2011 | 07:01 PM
martysmartie's Avatar
martysmartie
No nothing special, you can just simply extend the wire, the senders resistance changes with temperature (So essentially a thermistor), as the temperature increases the resistance decreases hence giving you a reading on the gauge and vice versa and so the reading decreases when cooler as the resistance has increased.
Martin
Old Feb 7, 2011 | 06:44 AM
As above extend at will, it will have a slight effect on the reading but nothing you'd be able to notice from the length extension needed on a car.
Most sensors are as stated in operation, known as NTC(negative temperature co effecient) , but you do also get PTS(positive) ones.
Old Feb 8, 2011 | 08:53 PM
Churtz's Avatar
Churtz
Out of curiosity...
Does this sensor have a live from the dash, and the sensor acts as a thermo resistor to the ground ( engine it's screwed into )?
Old Feb 8, 2011 | 09:27 PM
martysmartie
There is a switched feed which goes to the gauge and the earth for which is connected to the sender, it's works as I explained above. Basically as temperature increases the resistance decreases hence giving you the reading (NTC). This is a fairly old hat now, especially with modern cars/dashes most if not all are controlled by ECU which are far more accurate.
Martin
DixieTheKid
11
Jun 6, 2020 11:20 AM
15
Oct 7, 2015 03:43 PM
timsrs
22
Sep 24, 2015 08:14 PM
Si B
Sep 12, 2015 06:49 AM
Ben26
Sep 3, 2015 07:55 PM
